Go Back   Jemsite > Guitars and Gear > Other Ibanez Guitars
Other Ibanez Guitars Discussion about other Ibanez 6-string Guitars not covered in the above topics.
Old 09-28-2007, 01:08 AM
Stygian Stygian is offline
Posts: 317  -  iTrader: (6)
22-fret Ibanez neck on Ibanez RG? Can I?
I've got an 80s RG with the square neck joint. The frets has been giving me major buzz, and it just will not go away with truss adjustments alone. The best I can do with it is raise the action and play uncomfortably.
But, I've got a good spare Ibanez Proline neck with an ebony fretboard. It's 22 fret and I want to know if it's a problem? I've had it on the RG body once already, and it plays better than the original 24 fret neck. I did a quick measure of the scale lengths from each neck, from the nut to the center of the 12th fret, and they both are equal.
So I want to know if my intonation is going to be off balanced? Is this going to work?
Old 09-28-2007, 01:21 AM
Dee Dee is offline
Posts: 8,511  -  iTrader: (2)
Re: 22-fret Ibanez neck on Ibanez RG? Can I?
I don't see why not. It's the same scale length, it should be fine.
Old 09-28-2007, 01:32 AM
Yeah, I mean it'd be great if I could. I'm playing the guitar now, and it's bad. Now, the 24 fret neck has that overhang, so I know the 22 fret Ibanez Proline neck is going to leave a space, but I honestly don't think it looked too bad this way when I tried it.
So I know it's physically possible. I just want to be sure it won't sound bad tonally.
Old 09-28-2007, 01:33 AM
Ki swordsman Ki swordsman is offline
Posts: 1,506  -  iTrader: (0)
whoa hold up, the scale length is correct but if it previously had a 24 fret neck, and you're putting on a 22, ie 22 will be where 24 was. then you're essentially moving the entire neck towards the guitar and you'd need the bridge to move also, to keep the scale length.
on a 22 fretter the bridge will be placed closer to the tail than on a 24(of same scale).
so in intonation terms, sorry mate it won't work.
edit just saw you have an overhang- and the 22 doesn't? if so it may be close enough to work. just remember scale length has to be correct enough between bridge saddles and nut.
Old 09-28-2007, 01:35 AM
Ayrton's Avatar
Ayrton Ayrton is offline
Posts: 3,551  -  iTrader: (40)
With the same scale, you will be just fine.
I have swapped strat necks (21 vs 22 fret) necks in the same fashion.
Old 09-28-2007, 01:43 AM
yeah it all depends how close it is and how much room to be adjusted the saddles have..
Old 09-28-2007, 01:47 AM
mike-o mike-o is offline
Posts: 103  -  iTrader: (1)
The 2 extra frets on the old school square heel 24 fret necks were fingerboard extensions.
The neck pockets and scales should be the same, and you should have no problem.
Old 09-28-2007, 02:20 AM
Dee Dee is offline
It'll work fine, only it'll look a bit funny.
Old 09-28-2007, 04:56 AM
ibanezking ibanezking is offline
Posts: 423  -  iTrader: (11)
On ANY guitar or bass etc.....
Measure from nut to middle of 12th fret
Double it - thats your scale length
on an RG its 12 3/4 inches to the 12th = 25.5inch scale
you can put any neck on any guitar
AS LONG AS : nut to 12th = 12th to bridge saddle
Then all you're left with is the cosmetic appeal - or not
Max
Old 09-28-2007, 06:51 AM
aah cheers! well that's the key point then. in that case if they're the same length neck but with the extra 2 as fretboard hang, it'll be perfect.
Old 09-28-2007, 10:09 PM
Thanks guys confirming that the neck switch would work. I painted the blank space black and put the Ibanez Proline 22 fret neck on it today. I think it looks pretty good (not perfect), considering it has some nicks and the pickups are far from original anymore. It's been heavily modded.
The Ibanez Proline neck has a larger logo and is straight rather than angled, so it isn't the camera playing tricks. Although, the spot I painted REALLY shows up in a photo for some reason, maybe its the flash. I'm not sure I'll keep it this way, but it's nice to play on a neck without the buzz, and an ebony fretboarded guitar is ALWAYS a plus!
Old 10-09-2007, 06:35 PM
Oatman Oatman is offline
Posts: 31  -  iTrader: (0)
I'm thinking of something similar. What model and year was your proline with the ebony fretboard?
I know one of the rare JS models (I think the JS90) had an ebony fretboard... what other necks/modes had ebony fret boards that would be compatible wit this neck joint or the AANJ?
thanks!
  #13
Old 10-09-2007, 08:18 PM
guitvai1 guitvai1 is offline
Posts: 366  -  iTrader: (0)
If you were to take the guitar into a decent set up tech he/she should be able to level the frets and adjust the neck to get rid of the excess buzzing. I did it with an old RG and it cost me justy $65 and it plays better than ever.
  #14
Old 10-11-2007, 05:38 AM
thanks!
It was from a 1985 Pro Line. Aside from the funky look of the gap between the edge of the fretboard and neck pickup (not bad in real life), it plays well. It's definitely fatter than the original wizard neck, though! I notice I can't play quite as fast. I honestly don't know what other necks had ebony, but all the ones I've seen thus far have had the old square neck joint or were neckthru. I think they've all been Pro Line guitars too, some with different inlay or even binding.
  #15
Old 10-11-2007, 05:43 AM
Good idea, but I'm really cheap and don't know anybody locally that can do this work. Aside from that excuse, there may be a problem beyond the frets, because they do not look that worn down to me. Maybe my neck is out of whack beyond what a truss rod adjustment can fix? Anyways, I might play switcharoo with the necks a few times, but for now the replacement works!
TC Electronic G-System Integrated Guitar Effects and Controller
As low as $1475
at 7 sellers
Hal Leonard Acoustic Guitar Songs Method Suppliment Book with CD
As low as $8
at 10 sellers
Members with more than 50 posts don't see this bar
Peavey Vypyr Tube 60 60W 1x12 Guitar Combo Amp Black
As low as $360
at 11 sellers
Epiphone Futura Prophecy Custom EX Electric Guitar with Fixed Bridge Black Cherr
As low as $649
at 7 sellers
IK Multimedia AmpliTube 2 Electric Guitar Amplifier and Effects Modeling Plug-in
As low as $195
at 12 sellers
Breedlove Atlas Series Stage J350/EF-12 12-String Jumbo Acoustic-Electric Guitar
As low as $0
at 7 sellers
Mel Bay Modern Guitar Method Grade 5 Book - Expanded Edition
As low as $11
at 4 sellers
Guyatone Micro Series MO-3 Micro Octaver Pedal
As low as $90
at 10 sellers
Goldtone Weissenborn SM Solid Mahogany Top Acoustic Guitar
As low as $4
at 9 sellers
DR Strings Tite-Fit Big-n-Heavy Electric Guitar Strings
As low as $6
at 23 sellers
Graph Tech Trem-Nut String Trees (pair)
As low as $9
at 8 sellers
Dean Exotica Nomad Acoustic-Electric Travel Guitar Natural
As low as $270
at 4 sellers
Fender Deluxe Locking Machine Heads
As low as $54
at 7 sellers
Gibson Custom ES-335 Dot "Fat Neck" Reissue Electric Guitar Antique Ebony
As low as $3099
at 5 sellers
close
Sign up for free and join one of the largest communities of Jem guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
I agree to the website rules
