Old 03-25-2011, 06:36 PM
ozzuk  is offline
Posts: 212  -  iTrader: (2)
Reviews: 12
Re: Bowed Neck, how much is too much?
Surely back bow wouldnt be that bad, if the neck is twisted/warped thats another matter.
If this is in the UK mag and your unsure about getting it I wouldnt mind picking it up myself...
Old 03-25-2011, 07:14 PM
RGTFanatic  is offline
Posts: 6,096  -  iTrader: (14)
Images: 3
Unfortunately, back-bow can be that bad. There are two reasons that it can make a neck useless.
First; If the nut was too tight (putting the neck into back-bow) for an extended period of time, the maple can develop a "memory" of that position. With that "memory" the nut will loosen very quickly, putting little to no tension on the neck, but the neck has only rebound slightly.... but still in back-bow. I've been told that the neck can sometimes be brought back to original condition by steaming and clamping but in practice only seen this method add to the necks problems (twisting, cracking, de-laminating the fretboard)
The second reason is if a neck is exposed to extremely humid conditions for an extended period, without proper maintenance. Again the neck will bow, but because of the extra dampness the maple will develop "memory" again, but much faster. If this is the case, the repair process will be VERY long, and yield minimal, if any, results.
neck bow rg 550
Richie Kotzen's Electric Joy neck pickup, Ibz RBM pickguard & 1966 Fender Neck Plate mayzan Classified Ads: Guitars and Gear 0 11-30-2010 10:04 AM
FS: RG550 Maple neck/Edge Trem, Jackson neck, Dimarzio pups NickCormier Classified Ads: Guitars and Gear 10 01-08-2010 12:46 PM
Flamed jackson neck, birdseye musikraft neck, loaded strat body shesky Classified Ads: Guitars and Gear 2 04-30-2009 06:02 PM
SWAP: Jem neck 77FP tree of life and floral head for 777DY pyramid neck blitzmark1 Classified Ads: Guitars and Gear 2 03-19-2009 06:41 PM
ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only) 7-request Pickups & wiring 2 07-05-2005 11:18 AM
