Old 05-01-2008, 03:06 PM
mattacuk  is offline
Posts: 120  -  iTrader: (0)
Cleaning my Fretboard !!
Ok so since ive had my fabulous PGM i havent put it down. The fretboard is quite frankly filthy already! What is the best and easyiest way to clean it? what should i be useing to clean it? I read somehwere you shouldnt remove all the strings.
thanks!!
Old 05-01-2008, 03:29 PM
rvai  is offline
Posts: 458  -  iTrader: (0)
Re: Cleaning my Fretboard !!
theres a sticky thread about this is repairs/mods, that is all yo would need to know to get a beautiful clean maple board
Old 05-01-2008, 03:36 PM
mattacuk  is offline
thankyou. where is the sticky please?
Old 05-01-2008, 04:13 PM
70Seven  is offline
Posts: 204  -  iTrader: (0)
Is it maple or rosewood?
Is your bridge floating or not? Either way I wouldn't be afraid to remove all the strings, especially for cleaning the board, its much easier with no strings. If its a fixed bridge then no worries..
Old 05-01-2008, 04:46 PM
johliatay  is offline
Posts: 159  -  iTrader: (0)
Here is the link
http://www.jemsite.com/forums/showthread.php?t=75764
Old 05-01-2008, 04:56 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
you need to send it to me, unfortunately proper cleaning takes time, several years in some cases
Old 05-03-2008, 08:01 PM
Heavy Wood  is offline
Posts: 5  -  iTrader: (0)
I just cleaned my maple fretboard for the first time on a used RG470. Lighter fluid worked wonders!! It really does make it look like new. I couldn't believe it. The addition of using #0000 steel wool worked great.
Old 05-03-2008, 10:18 PM
theshape  is offline
Posts: 154  -  iTrader: (9)
something is bothering me about this, you guys say you use lighter fluid? like zippo lighter fluid, gas? doesnt your fretboard stink after that? god that smell never goes away.
also i would never use steel wool on a maple board, i would rather let it get dirty than sand it down and lose wood.
Old 05-04-2008, 12:33 AM
rdm  is offline
Posts: 82  -  iTrader: (0)
Steel Wool is cool as long as you don't get it or any of the metal shavings near your pups.
Old 05-04-2008, 12:19 PM
Lighter fluid is not gas, and it evaporates fairly quickly, and doesn't leave your fretboard smelling like the fluid. The steel wool WILL NOT sand away any wood. It's not a sanding action, it's just simply cleaning.
You can use #0000 steel wool on any fretboard, maple, rosewood, ebony. It's gentle enough that you don't have to worry about any scratching. Just use it gently enough that you don't scratch the inlays.
Steel wool works magic on the frets.... #0000 only.
fixed bridge, maple fret, maple fretboard, steel wool
Cleaning a Maple Fretboard Ironjose Tech: Setup, Repairs and Mods 4 04-15-2007 02:41 AM
Cleaning a maple fretboard, is lemon oil ok? carlos grijalva Tech: Setup, Repairs and Mods 1 08-18-2006 12:52 PM
Cleaning fretboard with Windex..Good/bad? KissMyAxe JS (Satriani Model) Ibanez Guitars 25 06-04-2006 07:00 AM
Just a few questions about fretboard cleaning Dr Mindcrime Tech: Setup, Repairs and Mods 6 10-27-2004 12:53 AM
Fretboard cleaning without steel wool Pesso Tech: Setup, Repairs and Mods 3 09-13-2004 02:34 AM
