Old 04-13-2007, 04:06 AM
Jeff_B  is offline
Posts: 36  -  iTrader: (0)
Considering a 1998 RG570JG and some Q's
Well I finally found a decent local deal on a '98 RG570 in Juniper Green. Plays real nice now that I'vve set the trem angle and lowered the bridge. I don't know that I can come to terms with the current owner; I hope so. It's pretty dinged up but the neck and fingerboard are in great shape; almost no fret wear.
Let me know what you think. Also, take a look at the pic of the trem claw. Is it normal for the claw to be this 'tight' with 3 springs and 10's?
Trem claw - is it normal to be this tight with 3 springs and 10's?
I think the bridge height and trem angle are good
It's pretty dinged up, and someone installed oversize eye hooks for strap buttons!
Old 04-13-2007, 04:14 AM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Re: Considering a 1998 RG570JG and some Q's
Hi Jeff. Yes, that's normal. There's quite a bit of pull on the trem using 10's, and short of using 4 springs it'll always look that tight when the bridge is parallel / balanced. With 9's there's about a quarter of an inch or so between the claw and the edge of the cavity.
Old 04-13-2007, 04:22 AM
Jeff_B  is offline
Hey, man...thanks!
If I take this guitar, it'll be my first Ibanez AND my first Floyd guitar.
Old 04-13-2007, 04:35 AM
brothersnowgone  is offline
Posts: 1,498  -  iTrader: (3)
Reviews: 7
Originally Posted by Jeff_B View Post
Hey, man...thanks!
AND you will never turn back ! The eye loops could be fixed easily, but I can't imagine who would think that was a good idea...
Old 04-13-2007, 11:33 AM
Jeff_B  is offline
Undoubtedly an EVH fan
Old 04-13-2007, 09:03 PM
speedy mcfeely  is offline
Posts: 293  -  iTrader: (1)
The trem is not set up right. you will need to releve some of the tension on th springs. you should look in the tech section of the main jemsite page. it has a few diagrams and detailed set up instructions for the edge trem.
Old 04-13-2007, 09:44 PM
Dee  is offline
Speedy's correct. If you're keeping 10's on it, slacken the claw screws a little and retune. It needs to come forward just a tiny amount. It is very close to level, though, you can see it clearly by looking at the side -- there's a line to help you level it, and it's almost straight.
Old 04-14-2007, 12:37 PM
560licious  is offline
Posts: 322  -  iTrader: (0)
Images: 4
To me it looks just the opposite. The bridge is in fact almost right, but it looks to me that the springs need a tad more tension...I thought the base of the bridge was what needs to be level? Also, it's cool that someone had enough sense to slap an Edge in there!
Old 04-14-2007, 12:59 PM
Dee  is offline
The 570 always came with an Edge.
Look -- see this part where I circled? This is the line that needs to be parallel with the body. Adding more tension to the springs will bring the bridge too far back, which is of course incorrect. This claw needs it's screws backing off just a fraction, literally just a quarter of a turn or something. You are thinking the top part needs to be parallel? Nope, it's supposed to be angled. See bottom pic.
Old 04-14-2007, 01:05 PM
Images: 4
ahhh...I see...lining it up with the blade...thanks Dee....But, on the bridge...that is an original Edge that they didn't use in 1998.
Old 04-14-2007, 01:08 PM
Dee  is offline
They did use the Edge in 1998. Here's a page from the 1998 catalog:
Old 04-14-2007, 01:13 PM
Images: 4
Wow, Thanks again Dee...I never see them on the newer ones, always the lo-pro or something.
Old 04-14-2007, 10:38 PM
In '92-'93 the 570s had lo-pro edge trems. they went back to the original edge for some reason around 1995 or 1996.
on a side note, I love the rg570, i like it better than my Jems.
Old 04-14-2007, 11:43 PM
Dee  is offline
You must have a great 570 there, speedy. What is it you prefer, the Wizard neck?
Old 04-14-2007, 11:55 PM
I think I like the fact that I can play the heck out of it. I am not worried about dinging it, or breaking the neck. I do however like the wizard profile allot. I can play anything from jazz to blues to metal. it is a great axe. The price is also way cheaper, and is pretty much the same guitar.
claw screws, edge trem, edge trems, pro edge, pro edge trem, pro edge trems, strap button, strap buttons, trem claw
rg 7620 1998 has blaze?
