Closed Thread
Old 10-07-2008, 12:27 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Re: Custom 8-string Iceman - Meshuggah!
Originally Posted by Of Angels View Post
Let's talk about that 8 string Iceman again...
Meshuggah... I don't understand what people like about them so much.
you said it too: LET'S TALK ABOUT THAT 8-STRING ICEMAN AGAIN... please people, start a new thread for anything that doesn't belong to this one. we already had 4 useless pages of cr*p. thanks.
  #92
Old 10-07-2008, 12:48 PM
Of Angels  is offline
Posts: 516  -  iTrader: (8)
Originally Posted by Ruggo View Post
I asume you havent heard Thorendals Special Defects? Its very Holdsworthian
Oy, I've heard good things about this! Thanks for the reminder.
  #93
Old 10-07-2008, 01:14 PM
Murder Soul  is offline
Posts: 31  -  iTrader: (0)
You've still missed the point. The point being that having such a substantial neck makes a world of difference. The scale length has little to do with it, and the extra two strings have everything to do with it. Tune it to whatever you want, but some musicians just prefer having more strings. It inspires them more. If you wanted to keep going higher and higher with the number of strings on each successive guitar you buy, well then ****ing do it pretty much. Who cares? If it hurts you in some way, looking into having a psycho-evaluation done, because it doesn't matter.
How does a substantial neck make a world of a difference when you just said the entire point is the other 2 strings? The argument earlier was that the necks are longer to help get the right tension, and I pointed out larger strings, or baritone guitars can be done on a mere 6 strings.
  #94
Old 10-07-2008, 01:24 PM
This will be the last comment made in this "argument", because you're simply incapable of adding things together. Somebody else pointed out that the longer scale gives you the right tension. My point is that adding two strings and (sometimes) a longer scale gives you a more substantial neck, which has everything to do with the instrument feeling different. This point is irrefutable and not a matter of opinion. End.
  #95
Old 10-07-2008, 01:38 PM
musicdr  is offline
Posts: 671  -  iTrader: (0)
I think it comes down to whatever inspires a person to create music.I have a couple of 7 strings.I don't gig with them.I do write with them.They make me think differently than a six.So I write things I normally may not.I usually transpose that to a six. whatever inspires someone is a good thing.
  #96
Old 10-07-2008, 02:38 PM
You're simply incapable of sticking to your argument.
Once again, the idea, for me at least, is in the shape/size/feel of the instrument. You making mention of others who tune 6 stringers low holds no ground in response to what I said. My point is that those carpal tunnel inducing instruments have longer scales, which provide different tonal characteristics and the propensity to sound tighter with lower tunings. While Meshuggah, in my opinion, makes boring use of the low strings, and not much else, who's to say that they would have wrote their most recent albums without those 8 strings? Creativity is something that knows no boundaries, and it is indeed wrong to try to form them, regardless of whether or not you approve of whatever it is you want to criticize.
Your point was that they have longer scales. There's this thing called a baritone guitar, specifically designed for such a thing. Not to mention you can tune as low as you want, you just have to put bigger strings on.
Reminds me of the nu-metal gone metalcore fag Dino. In his little youtube video about 8 strings he was complaining about how tuning lower the strings got floppy, so he went to a 7. 7's have the exact same scale length as 6's (Ibanez). Apparently the idiot didn't know how to change his strings.
Now on your thing about a different feel of the neck. You like wider necks? So you're going to buy an 8 string just so you're neck is 3 1/2" wide? Then that's all personal preference. Has nothing to do with "creativity".
  #97
Old 10-07-2008, 03:20 PM
Don't tell me what my point was. My point was that more strings and SOMETIMES a longer scale changes the feel of the instrument entirely. You've failed to get everything straight in this exchange of words. The comments about the longer scale came about when you stated that all you had to do was use bigger strings.
It absolutely does have something to do with creativity. If I sit down and play a bass, I'm going to write different music than I would on a guitar. If I sit down and play an accordian, I'm going to make different music than I would on a piano. If I sit down and play a guitar that has two extra strings, I'm going to make different music than on a 6 string guitar. Making music = being creative. Having a different instrument = creating differently. If this doesn't make sense to you, then I'm going to assume that you aren't capable of understanding, and it's not my desire to make enemies online.
Love and let live, my friends.
  #98
Old 10-07-2008, 04:40 PM
MFB  is offline
Posts: 598  -  iTrader: (1)
I'm actually gonna write a 5-7 page paper on this argument of 6 string vs 7/8/12/etc
Most likely get a B if I do good research and whatnot
And here I thought I wouldn't be able to find a pro/con topic, silly me
  #99
Old 10-07-2008, 04:50 PM
That's not a bad idea, man. And here we were acting like all of this argumentation was useless :-D
Good luck on that.
  #100
Old 10-07-2008, 04:53 PM
mrjakob69  is offline
Posts: 448  -  iTrader: (2)
personal preference has every little thing to do with creativity, when you are comfortable on your instrument you play it much different then when you are not comfortable.....this month in guitar world kirk hammit talks about his action, its pretty high because he likes to fight it a little otherwise he gets lazy and plays bad.
  #101
Old 10-07-2008, 11:25 PM
GuitarBizarre  is offline
Posts: 1,184  -  iTrader: (0)
Originally Posted by mrjakob69 View Post
kirk hammit talks about his action, gets lazy and plays bad.
Fixed.
  #102
Old 10-07-2008, 11:57 PM
You failed to make a solid argument at all.
Strange, I played bass before I started to play guitar. I quit liking bass, but now everything I came up with on bass is easier to play on guitar. I write my music, then play it on the instrument. I don't let it dictate what I play.
I do have to agree with you to an extent. It seems almost all extended rangers only play the lower strings, and argument I made earlier.
  #103
Old 10-08-2008, 02:57 AM
The key to it is that the instrument inspires you to play/write differently, it doesn't dictate. That's narrow-minded as all ****, really. Using various forms of inspiration, including the feel and functionality of an instrument, is highly enjoyable if you really enjoy writing music. I can write a whole world of music on a 6 string, and likewise on a 7 string, and likewise on a piano, and likewise on a bass, etc. Even if this isn't the way things work for everybody (because it's apparently far beyond your comprehension), its how things work for me.
Look dude, you seem like you're just looking for an argument, and to be honest, it's stupid.
If you want to play your bass lines on your guitar, then go ahead, because that makes sense and what not. If you get no benefit from playing one instrument as opposed to another, then you're simply missing out on something that I would consider inspiring. If you have no problem with that, then I'm happy for you, but either way, I don't really care. I don't care what music you think is good, how many strings you think a guitar should have, or if you can hold yourself up in an argument. All of that is 100% irrelevant to me, so drop it, dude.
  #104
Old 10-08-2008, 03:10 AM
Lefty Robb  is offline
Yeah, this thread has really gotten out of hand.
  #105
Old 10-08-2008, 03:13 AM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
closing this thread for a few days won't hurt ...glen
Closed Thread
buttsex, joe perry, speaker cab, ted nugent, wound strings
Meshuggah 8 string Ibanez Wound Other 7-string Guitars 80 11-08-2009 02:02 PM
Meshuggah 8 string Aris_T Other 7-string Guitars 19 05-14-2007 01:21 PM
meshuggah and blaze custom tecnorud Pickups & wiring 1 02-27-2006 06:55 PM
Lundgren Custom Meshuggah pup... Wound Other 7-string Guitars 54 02-14-2006 12:26 PM
Nevborn Sleipner XL (Meshuggah 8-string) Chud Other 7-string Guitars 1 10-12-2003 11:43 AM
