Old 03-22-2008, 01:25 PM
afireinside7444  is offline
Posts: 153  -  iTrader: (3)
Custom parts compatability?
Ok looking to get a custom body swirled by perel guitars on **** (any reviews on them????)
And I can get a RG320 DXQM with a good neck but dinged body for $100.00. Both are AANJ will they work? are all AANJ same profile for mounting??
Old 03-22-2008, 03:25 PM
Lefty Robb  is offline
Re: Custom parts compatability?
If the guy who build the body did his homework, then yes.
Old 03-23-2008, 12:54 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
I bought one of those bodies and have some minor gripes about it. First off, the handle routing may look correct from the front, but on the back it is not done like Ibanez. Secondly, the neck mounting screws do not line up with a standard RG550/570 neck correctly(maybe a Korean neck will fit better?). The Japanese neck was too far forward by several mm(big gap between the neck pickup and the end of the fingerboard) and would never have intonated(the solution is to drill new holes in the neck heel). Also, you will have to drill some holes to get wiring thru to the pickup cavities and trem route for the ground wire. The pickup holes have flat bottoms so you may or may not need to make adjustments for whatever pickups you install. Go here
http://picasaweb.google.com/albro1952/SwirlJem
and click the SLIDESHOW button to see one assembled. Also note that the cover routing is a little too deep so Ibanez covers are sort of sunken in.
Old 03-23-2008, 03:49 PM
Then I guess the guy didn't do his homework...
neck pickup, pickup cavities
'Custom' Ibanez Shredder stuck in the 80s JEM and Universe Guitars 40 05-16-2007 03:01 PM
Custom Parts eclecticmage Tech: Setup, Repairs and Mods 5 10-06-2006 04:38 AM
Totally customizing the RBM1 or a custom PGM? RCB Other Ibanez Guitars (including Premiums) 1 10-06-2004 12:27 PM
EVH Custom Shop Guitars - Opens on March 1, 2002 pri0531 Other 6-string Guitars (non-Ibanez brand) 5 03-02-2002 09:47 AM
Looking for replacement (custom) JEM pickguards - JEM Parts Biker Buck Other 6-string Guitars (non-Ibanez brand) 1 11-19-2001 08:35 AM
