Old 12-11-2008, 05:23 PM
mugatu  is offline
Posts: 9  -  iTrader: (0)
direct lo-TRS replacement ?
hi !
the bridge of my japanese RG470 is pretty dead ! it's a japanese lo TRS made by takeuchi in 2001 =D
so , what bridges are direct replacement for it ? i don't want to route my guitar , i just want to replace this old crap with a new one .
oh , and i want of course a playable guitar after replacing the bridge ! good intonation , smooth playing ... you know , i love my RG470 to ****ing death ...
sorry if the question has been asked thousand times ... thx in advance
Old 12-11-2008, 05:27 PM
mugatu  is offline
Re: direct lo-TRS replacement ?
oops ! i just forgot to say i don't care about the brand ...
is a lo-TRS II a good replacement for my old lo TRS ?
because if it is ... yaw , it will be new , i could have it in gold ...
(yeah , on a black guitar , will be a bit funky but , yeah ... it will give more of derelique attitude to my guitar)
Old 12-11-2008, 05:35 PM
Foulacy  is offline
Posts: 354  -  iTrader: (0)
original floyd rose drops right in! you will need to shim the saddles to match the radius, allparts has shims for $10 and if you get a floyd rose "the key" life is 100x easier with a floyd.
and a lo-trs ii is even WORSE than a lo-trs which isn't all THAT bad. stay far far away from lo-trs ii and even further away from an edge iii.
Old 12-11-2008, 06:53 PM
callen3615  is offline
Posts: 1,412  -  iTrader: (7)
yeah i m getting an ofr or a gotoh for my js
Old 12-11-2008, 07:11 PM
mugatu  is offline
wow , i can drop an OFR directly on my cherished guitar ?
that's really cool ... so the OFR has the same stud spacing ?? and ... since i don't mod my guitar i hope intonation will be pretty good after adjusting it ? i believe there's no problem here ...
oh , and i'll check the shims on allparts ! thx !
oh , gotoh ?? same stud spacing or ... ? (i have bad english and i assume stud means that pair of little adjustable screws holding the "block" ) and what about intonation ?
Old 12-11-2008, 07:22 PM
mugatu  is offline
huh , i'm stupid ...
http://www.jemsite.com/jem/trems.htm
"Best Choice Option - If you have a TRS/TRS-II equipped Ibanez guitar, you can install the Floyd Rose Original/Pro without any modifications to your guitar. That is the easiest and best alternate."
cool !
Old 12-11-2008, 11:21 PM
Foulacy  is offline
yea it's sweet. i dropped a floyd in a lo-trs route. there's a little more spacing around the floyd (like between the walls of the route and the floyd) but i didn't have to do much intonating, only matching the radius.
Old 12-12-2008, 03:57 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
as a rule of thumb, ANY Floyd licensed trems drops right into TRS/LoTRS/LoTRS-II cavity with no routing mods, as the TRS-style trem is way bigger than any of those. and so is the trem block.
Old 12-12-2008, 05:53 AM
mugatu  is offline
cool ! i think OFR is the real deal
you know , sturdy floyd rose , screaming dimarzios w/ groovy colors and funky pots , here's the deal : my very own signature shred machine ... ya know i'm giving guitar lessons and working on some zappa-influenced shred band and i'd love my beloved guitar to scream even more !!
Old 12-12-2008, 07:12 AM
Crazy_Guitar  is offline
Posts: 1,319  -  iTrader: (0)
Reviews: 4
I have an RG470.
I have replaced the TRS with an OFR Pro. Had to route a deeper cavity and enlarge it a bit on the bottom.
Reccomend it!
Old 03-26-2011, 05:17 PM
JPM7stringfan  is offline
Posts: 149  -  iTrader: (1)
I have a spare Original Edge, will that fit an RG470?
Old 03-26-2011, 05:41 PM
LonePhantom  is offline
Posts: 5,368  -  iTrader: (6)
Reviews: 98
Have you tried it? Easiest way to find out!
They can usually fit, but sometimes the cavity needs some coercing to fit. Nothing some sandpaper wont sort out.
Old 03-26-2011, 05:48 PM
I don't have the 470 yet, just won it off the 'bay.
Old 03-26-2011, 06:17 PM
AlaskaBat  is offline
Contributor
Posts: 6,645  -  iTrader: (17)
Images: 11
Reviews: 94
If it's an early MIJ 470--yes, as those came stock with an Edge. If not, then you have a little routing to do:
http://projectguitar.com/tut/trs2lopro.htm
It's an easy job, and can be done with a Dremel.
Old 03-26-2011, 06:24 PM
It's a 1999 RG470, pics the seller posted weren't really good, but it definitly has a TRS trem, and I think it's new penny finish.
boobs, ibanez, lo trs, rg470, sex
sr505 direct replacement pickups and bridge id Pickups & wiring 11 07-27-2010 03:52 PM
ZR direct replacement arm holder lcsdds Other Ibanez Guitars (including Premiums) 3 10-03-2007 07:22 PM
Direct TV michblanch Off-topic / Miscellaneous 19 06-29-2007 12:15 PM
Is the Lo-Pro a direct replacement for the Edge cavity wise? dacmo Archived Topics and Common Questions - GO HERE FIRST 11 02-02-2004 02:35 PM
Is the Lo-Pro a direct replacement for the Edge cavity wise? dacmo Tech: Setup, Repairs and Mods 7 04-04-2001 02:37 AM
