easiest way to remove paint from a guitar? - Jemsite
post #1 of 33 (permalink) Old 04-27-2010, 09:47 PM Thread Starter
I need to refinish an RG that i just bought.... i will need to remove all the paint. what is the best method for doing this? heat gun and scraper? belt sander?
how can i best perform this task.
scottop1972 is offline
post #2 of 33 (permalink) Old 04-27-2010, 09:52 PM
Reviews: 98
Re: easiest way to remove paint from a guitar?
There was a thread just like this one less than a week ago... Anyway, a heat gun will do a great job, just make sure to scrape away the goo as you go along.
AlaskaBat is offline
post #3 of 33 (permalink) Old 04-27-2010, 10:42 PM
CosmicDebris's Avatar
Grenade
CosmicDebris is offline
post #4 of 33 (permalink) Old 05-04-2010, 11:01 PM
Reviews: 12
do not try propane torch lol. I ended up sanding most of mine off I used a orbital air sander and a paper flapper wheel in tighter rounded aeas. the only issue is you have to make sure once you are down to wood to make sure you use a block and get it all flat again. I did hear that Heat gun will work and I think it kinda flakes off just keep movins so you don't scorch wood unless you want a burnt look. I have seen soem look really sweet and with teh paint you can get some really cool patterns as the paint pops off at different rates alowing to burn uniques patterns in the wood. it was a minor burn almos like a light to medium toasting.
spudler_t is offline
post #5 of 33 (permalink) Old 05-04-2010, 11:49 PM
Heat Gun and scraper , paints almost jumps off when you heat it with a heat gun.
Robstar is offline
post #6 of 33 (permalink) Old 05-05-2010, 09:54 AM
You might find that after you've burned the body trying to get paint off evenly and sanded it out of shape you can get whatever is left off with a chemical stripper - semi paste, and let it set until it starts to dry. Whatever you do is going to alter the body some, so buckle up. I found pretty good results using a 5" random orbital sander, starting with 80 grit and progressing to 320 as the paint came off - at least on the front and back. On the sides I used a drum sander on a cordless drill - I think I used 120 then 320 grit (maybe with 220 in there, too). I was surprised at how thick the paint and clearcoat was on the RG I stripped recently, almost like a skin of plastic over the whole thing, so fair warning. Whatever you do, it will be more work than you think it will.
lwchafin is offline
post #7 of 33 (permalink) Old 05-05-2010, 12:11 PM
Pay someone else to do it.
toneboy is offline
post #8 of 33 (permalink) Old 05-05-2010, 02:10 PM
Wink Re: easiest way to remove paint from a guitar?
Bright boy, he.
lwchafin is offline
post #9 of 33 (permalink) Old 05-05-2010, 11:08 PM Thread Starter
i will be checking into this for sure!
any one know where i can by some Desert yellow paint?
post #10 of 33 (permalink) Old 05-05-2010, 11:20 PM
Stripping an RG is hell!!! LOL
I stripped 2 of mine over the years using all of the above methods and took my time. Both of my RG's had thick goopy layers and layers and layers that seemed to be like what lwchaffin said above.
Dont get impatient and plan for a long tough road. Let chemical strippers work, and get some good quality sandpaper..you'll be thankful you did.
If you plan to repaint you should be in good shape.
Phineas J is offline
post #11 of 33 (permalink) Old 05-06-2010, 10:33 AM
I've refinished furniture using a chemical stripper called Marine Remover that you can buy at any paint store. Use it with steel wool and gloves. The steel wool won't gouge up the surface.
Takin' a Ride is offline
post #12 of 33 (permalink) Old 05-06-2010, 10:36 AM
IbanezFreak777's Avatar
Reviews: 25
I never have issues, I just use a powered sander... to damn easy.. No RG is safe under my sander...
IbanezFreak777 is offline
post #13 of 33 (permalink) Old 05-06-2010, 01:17 PM
I find that some coarse sandpaper and a palm sander will do the trick really well on the front and back. doing the sides is awful but you can retain the factory sealant on the guitar if you are careful.
Bmax is offline
post #14 of 33 (permalink) Old 05-06-2010, 08:06 PM
I guess my preference for a chemical remover is that you won't remove any of the underlying wood or square up the chamfers on the edges of the guitar. You can also get the paint out of the pickup cavities that way.
post #15 of 33 (permalink) Old 05-07-2010, 11:03 AM
Sand it.
grafvonhattn is offline
diy , paint , remove
Human Verification
How do you REMOVE a fretboard from a guitar? Verus JEM and Universe Guitars 5 02-12-2010 10:29 AM
Easiest guitar to play? toddw7 Other 6-string Guitars (non-Ibanez brand) 32 12-18-2008 12:03 PM
Easiest way to memorize fretboard? jemuniverse777 Guitar Lessons & Music Theory 16 01-04-2007 08:59 PM
Easiest way to... HiMyNameIs JEM and Universe Guitars 5 01-14-2005 08:00 PM
