easiest way to remove paint from a guitar? - Jemsite
Old 04-27-2010, 10:47 PM
scottop1972  is offline
Posts: 571  -  iTrader: (1)
I need to refinish an RG that i just bought.... i will need to remove all the paint. what is the best method for doing this? heat gun and scraper? belt sander?
how can i best perform this task.
Old 04-27-2010, 10:52 PM
AlaskaBat  is offline
Posts: 9,291  -  iTrader: (18)
Reviews: 98
Re: easiest way to remove paint from a guitar?
There was a thread just like this one less than a week ago... Anyway, a heat gun will do a great job, just make sure to scrape away the goo as you go along.
Old 04-27-2010, 11:42 PM
CosmicDebris  is offline
Posts: 3,980  -  iTrader: (7)
Grenade
Old 05-05-2010, 12:01 AM
spudler_t  is offline
Posts: 90  -  iTrader: (0)
Reviews: 12
do not try propane torch lol. I ended up sanding most of mine off I used a orbital air sander and a paper flapper wheel in tighter rounded aeas. the only issue is you have to make sure once you are down to wood to make sure you use a block and get it all flat again. I did hear that Heat gun will work and I think it kinda flakes off just keep movins so you don't scorch wood unless you want a burnt look. I have seen soem look really sweet and with teh paint you can get some really cool patterns as the paint pops off at different rates alowing to burn uniques patterns in the wood. it was a minor burn almos like a light to medium toasting.
Old 05-05-2010, 12:49 AM
Robstar  is offline
Posts: 215  -  iTrader: (0)
Heat Gun and scraper , paints almost jumps off when you heat it with a heat gun.
Old 05-05-2010, 10:54 AM
lwchafin  is offline
Posts: 90  -  iTrader: (1)
You might find that after you've burned the body trying to get paint off evenly and sanded it out of shape you can get whatever is left off with a chemical stripper - semi paste, and let it set until it starts to dry. Whatever you do is going to alter the body some, so buckle up. I found pretty good results using a 5" random orbital sander, starting with 80 grit and progressing to 320 as the paint came off - at least on the front and back. On the sides I used a drum sander on a cordless drill - I think I used 120 then 320 grit (maybe with 220 in there, too). I was surprised at how thick the paint and clearcoat was on the RG I stripped recently, almost like a skin of plastic over the whole thing, so fair warning. Whatever you do, it will be more work than you think it will.
Old 05-05-2010, 01:11 PM
toneboy  is offline
Posts: 1,676  -  iTrader: (2)
Pay someone else to do it.
Old 05-05-2010, 03:10 PM
lwchafin  is offline
Wink
Bright boy, he.
Old 05-06-2010, 12:08 AM
i will be checking into this for sure!
any one know where i can by some Desert yellow paint?
Old 05-06-2010, 12:20 AM
Phineas J  is offline
Posts: 31  -  iTrader: (0)
Stripping an RG is hell!!! LOL
I stripped 2 of mine over the years using all of the above methods and took my time. Both of my RG's had thick goopy layers and layers and layers that seemed to be like what lwchaffin said above.
Dont get impatient and plan for a long tough road. Let chemical strippers work, and get some good quality sandpaper..you'll be thankful you did.
If you plan to repaint you should be in good shape.
Old 05-06-2010, 11:33 AM
Takin' a Ride  is offline
Posts: 5,160  -  iTrader: (40)
I've refinished furniture using a chemical stripper called Marine Remover that you can buy at any paint store. Use it with steel wool and gloves. The steel wool won't gouge up the surface.
Old 05-06-2010, 11:36 AM
IbanezFreak777  is offline
Posts: 4,163  -  iTrader: (11)
Reviews: 25
I never have issues, I just use a powered sander... to damn easy.. No RG is safe under my sander...
Old 05-06-2010, 02:17 PM
Bmax  is offline
Posts: 28  -  iTrader: (0)
I find that some coarse sandpaper and a palm sander will do the trick really well on the front and back. doing the sides is awful but you can retain the factory sealant on the guitar if you are careful.
Old 05-06-2010, 09:06 PM
I guess my preference for a chemical remover is that you won't remove any of the underlying wood or square up the chamfers on the edges of the guitar. You can also get the paint out of the pickup cavities that way.
Old 05-07-2010, 12:03 PM
grafvonhattn  is offline
Posts: 15  -  iTrader: (0)
Sand it.
diy , paint , remove
How do you REMOVE a fretboard from a guitar? Verus JEM and Universe Guitars 5 02-12-2010 11:29 AM
Easiest guitar to play? toddw7 Other 6-string Guitars (non-Ibanez brand) 32 12-18-2008 01:03 PM
Easiest way to memorize fretboard? jemuniverse777 Guitar Lessons & Music Theory 16 01-04-2007 09:59 PM
Easiest way to... HiMyNameIs JEM and Universe Guitars 5 01-14-2005 09:00 PM
Powered by
