Edge pro tuning problem. Is the EZII better? - Page 9 - Jemsite
post #121 of 177 (permalink) Old 11-06-2012, 09:12 PM
Reviews: 120
Re: Edge pro tuning problem. Is the EZII better?
And it it takes is a bit of metal polish, a rag and elbow grease to polish hideous looking hardware to a nice chrome finish!
LonePhantom is offline
post #122 of 177 (permalink) Old 11-06-2012, 09:24 PM
RGTFanatic's Avatar
Here,Here!!!!
good answer my man!!!
RGTFanatic is offline
post #123 of 177 (permalink) Old 11-07-2012, 06:37 PM Thread Starter
Originally Posted by Rich View Post
Please confirm on deny this fully describes your problem.
I confirm
FriedShrimps is offline
post #124 of 177 (permalink) Old 11-07-2012, 06:44 PM Thread Starter
Originally Posted by RGTFanatic View Post
This can be addressed later.....again, just a setup issue. Thanks for clarifying.....
You're welcome
post #125 of 177 (permalink) Old 11-07-2012, 06:48 PM Thread Starter
Okay, thanks!
post #126 of 177 (permalink) Old 11-07-2012, 07:36 PM
Originally Posted by FriedShrimps View Post
I confirm
Then raise the action and test again. If it's no different, the fix is the same I've ben saying the whole time, lube, /and/or stud mod. If you want to sell the guitar instead of fixing it is your business.
Your trem needs nothing more than a good wipedown with spit on a soft cloth to look good again.
Rich is offline
post #127 of 177 (permalink) Old 11-07-2012, 07:51 PM
CosmicDebris's Avatar
Amen Mr. Harris.
CosmicDebris is offline
post #128 of 177 (permalink) Old 11-10-2012, 11:03 AM Thread Starter
I took the springs off and removed the trem. I cleaned it, placed the saddles correctly and lubed the studs and rasied the action. I did not replace the springs though. But it stays in tune better now. It still wants goes sharp and flat (in standart tuning) when I dive, but less than before. Do you think replacing the springs would complete the Edge Pro and make it good as new?
And I really shouldn't be afraid of replacing the trem again, it wasn't that bad
post #129 of 177 (permalink) Old 11-10-2012, 11:48 AM Thread Starter
Hey Rich. I know this sounds weird but I placed the springs like this: /|\ because I like when the tension is released at the ligher strings.. And after I did that my RG1570 stays in tune perfectly. Soo.. All this could just be fixed by lubing the studs? If so I feel really stupid for not listening to you. But I've learned a lot from this thread. I bough a RG570 Purple pearl yesterday with the Original Edge. It was poorly set up, so I adjusted the saddles, lubed the studs and cleaned the fretboard and balanced the trem all by my self. And the guitar is wonderful. I'm really happy that I can do all this by my self now. And I only payed 340$ which is very cheap even though it's used
post #130 of 177 (permalink) Old 11-10-2012, 02:10 PM
Its because the the /\ springs are stretched further and the coils have less friction on the coils.
Like I said in the beginning.
sebastian is offline
post #131 of 177 (permalink) Old 11-10-2012, 02:22 PM
[quote=FriedShrimps; And the guitar is wonderful. I'm really happy that I can do all this by my self now. [/quote]
Well that's a good thing,as you said yourself you learned a lot from all of this, and that is usually the case-when something isen't quite right and one have to fix it,learning is the consequence. And in this case it turned out to be a moneysaver in the future.
maqify is offline
post #132 of 177 (permalink) Old 11-10-2012, 04:17 PM
Reviews: 120
Hooray, finally! It's a pity it took 9 pages of posts for you to finally accept the advice and try it, but at least you got there in the end.
post #133 of 177 (permalink) Old 11-10-2012, 04:53 PM
All you needed was the lube, the right lube, but lube was all it needed.
Please stop. You don't realize there is zero "friction" in a coil whether it's closed or open?
Rich is offline
post #134 of 177 (permalink) Old 11-10-2012, 05:12 PM
That advice applies to other stuff than guitars. Buy in bulk and save some money.
post #135 of 177 (permalink) Old 11-10-2012, 05:30 PM
Hahahhahhahhah....
maqify is offline
edge pro , edge zero , ibanez rg , tuning
Human Verification
Ibanez Lo-Pro Edge Tuning Problem VexHead Other Ibanez Guitars (including Premiums) 15 08-26-2011 02:10 PM
Edge 3 Tuning problem!!! prydogga Tech: Setup, Repairs and Mods 30 06-26-2010 10:10 AM
Edge Pro Tuning Stability Problem TheYoungGuitarist Tech: Setup, Repairs and Mods 1 01-14-2009 09:10 PM
edge tuning problem..... caprile Tech: Setup, Repairs and Mods 3 05-24-2002 02:52 AM
edge tuning problem - edge tuning problem johank Tech: Setup, Repairs and Mods 1 10-03-2001 09:30 AM
