Edge pro tuning problem. Is the EZII better?
Page 9 of 12
11-06-2012, 09:12 PM
LonePhantom
Posts: 7,226 - iTrader: (
Reviews: 120
Re: Edge pro tuning problem. Is the EZII better?
And it it takes is a bit of metal polish, a rag and elbow grease to polish hideous looking hardware to a nice chrome finish!
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
122
11-06-2012, 09:24 PM
RGTFanatic
Posts: 6,111 - iTrader: (
LonePhantom
Here,Here!!!!
good answer my man!!!
__________________
RGTFanatic
Visit RGTFanatic's homepage!
Find all posts by RGTFanatic
11-07-2012, 06:37 PM
FriedShrimps
Posts: 79 - iTrader: (
Please confirm on deny this fully describes your problem.
I confirm
FriedShrimps
Find all posts by FriedShrimps
124
11-07-2012, 06:44 PM
FriedShrimps
RGTFanatic
This can be addressed later.....again, just a setup issue. Thanks for clarifying.....
You're welcome
FriedShrimps
125
11-07-2012, 06:48 PM
FriedShrimps
LonePhantom
Okay, thanks!
FriedShrimps
126
11-07-2012, 07:36 PM
Posts: 20,371 - iTrader: (
FriedShrimps
I confirm
Then raise the action and test again. If it's no different, the fix is the same I've ben saying the whole time, lube, /and/or stud mod. If you want to sell the guitar instead of fixing it is your business.
Your trem needs nothing more than a good wipedown with spit on a soft cloth to look good again.
11-07-2012, 07:51 PM
CosmicDebris
Posts: 3,618 - iTrader: (
Amen Mr. Harris.
CosmicDebris
Find all posts by CosmicDebris
128
11-10-2012, 11:03 AM
FriedShrimps
I took the springs off and removed the trem. I cleaned it, placed the saddles correctly and lubed the studs and rasied the action. I did not replace the springs though. But it stays in tune better now. It still wants goes sharp and flat (in standart
tuning
) when I dive, but less than before. Do you think replacing the springs would complete the
Edge Pro
and make it good as new?
And I really shouldn't be afraid of replacing the trem again, it wasn't that bad
FriedShrimps
129
11-10-2012, 11:48 AM
FriedShrimps
Hey Rich. I know this sounds weird but I placed the springs like this: /|\ because I like when the tension is released at the ligher strings.. And after I did that my RG1570 stays in tune perfectly. Soo.. All this could just be fixed by lubing the studs? If so I feel really stupid for not listening to you. But I've learned a lot from this thread. I bough a RG570 Purple pearl yesterday with the Original Edge. It was poorly set up, so I adjusted the saddles, lubed the studs and cleaned the fretboard and balanced the trem all by my self. And the guitar is wonderful. I'm really happy that I can do all this by my self now. And I only payed 340$ which is very cheap even though it's used
FriedShrimps
130
11-10-2012, 02:10 PM
sebastian
Posts: 2,204 - iTrader: (
Its because the the /\ springs are stretched further and the coils have less friction on the coils.
Like I said in the beginning.
sebastian
Find all posts by sebastian
131
11-10-2012, 02:22 PM
maqify
Posts: 1,270 - iTrader: (
[quote=FriedShrimps; And the guitar is wonderful. I'm really happy that I can do all this by my self now.
[/quote]
Well that's a good thing,as you said yourself you learned a lot from all of this, and that is usually the case-when something isen't quite right and one have to fix it,learning is the consequence. And in this case it turned out to be a moneysaver in the future.
maqify
Find all posts by maqify
132
11-10-2012, 04:17 PM
LonePhantom
Reviews: 120
Hooray, finally! It's a pity it took 9 pages of posts for you to finally accept the advice and try it, but at least you got there in the end.
LonePhantom
133
11-10-2012, 04:53 PM
FriedShrimps
All you needed was the lube, the right lube, but lube was all it needed.
sebastian
Please stop. You don't realize there is zero "friction" in a coil whether it's closed or open?
11-10-2012, 05:12 PM
CosmicDebris
That advice applies to other stuff than guitars. Buy in bulk and save some money.
CosmicDebris
135
11-10-2012, 05:30 PM
maqify
CosmicDebris
Hahahhahhahhah....
maqify
Page 9 of 12
edge pro
edge zero
ibanez rg
tuning
Ibanez Lo-Pro Edge Tuning Problem
VexHead
02:10 PM
Edge 3 Tuning problem!!!
prydogga
Tech: Setup, Repairs and Mods
30
06-26-2010
10:10 AM
Edge Pro Tuning Stability Problem
TheYoungGuitarist
09:10 PM
edge tuning problem.....
caprile
02:52 AM
edge tuning problem - edge tuning problem
johank
09:30 AM
11:54 AM
