Old 05-26-2008, 12:05 PM
taracatac  is offline
Posts: 873  -  iTrader: (18)
Edge Pro vs. Edge Zero
Does anyone know if the Edge Zero is interchangeable with the Edge Pro and vice versa without modification? Are the posts interchangeable as well?
Old 05-26-2008, 12:18 PM
Crazy_Guitar  is offline
Posts: 1,319  -  iTrader: (0)
Reviews: 4
Re: Edge Pro vs. Edge Zero
No. The trem blocks and springs are different.
Old 05-26-2008, 06:14 PM
Actually, to be more specific, can you put the Edge Zero trem and ZPS system into say, a 1570 body, without modding the body?
Old 05-27-2008, 07:47 AM
Reviews: 4
I have the idea that the Edge Zero requires a slightly smaller route than the Edge Pro. You might be able to do that.
But ask Rich, I bet he knows that.
Old 05-27-2008, 07:22 PM
rvai  is offline
Posts: 458  -  iTrader: (0)
looking at the pictures I think the edge zero route is way bigger
Old 05-27-2008, 07:45 PM
lcsdds  is offline
Posts: 186  -  iTrader: (0)
I wonder if you could use the Edge Pro trem in conjunction with Edge Zero springs. Would make it alot easier to adjust the spring tension with the thumbwheel instead of a screwdriver. Probably not but it would be interesting to see if it might work. I wonder if this would work with an original Edge or a LoPro?
edge pro trem, edge zero, trem block
edge pro to lo pro rya JEM and Universe Guitars 42 05-11-2011 03:54 AM
edge 3 to lo pro edge hoockey Other Ibanez Guitars (including Premiums) 16 11-22-2006 05:15 AM
Can I use Edge posts with an Edge Pro?? PatrickSimsCustomShopUSA Tech: Setup, Repairs and Mods 8 10-26-2006 11:00 AM
String spacing of Edge/Lo-Pro vs Edge Pro MetalZone J-Custom, USA Custom & Prestige Ibanez Guitars 21 10-24-2006 08:59 AM
Edge III Mystery... Solved? eclecticmage Tech: Setup, Repairs and Mods 47 10-22-2006 01:08 PM
