The only thing it might be is the sustain block, which is taller on the original (non-recessed) versions used on the
RoadStar series. If you install a long-blobk version on say an RG550, the block will stick out the back just a little bit. Pretty sure the blocks are interchangeable and held on with 3 flat-headed phillips screws that hide under the
bridge saddles.
