Closed Thread
Old 03-18-2001, 12:08 PM
jhczar  is offline
Posts: 14  -  iTrader: (0)
Edge Tremolo problem (RG570) - Won't stay in tune after pull
I've got an RG570DX, purchased new 3 days ago, with an Edge Tremolo. *It appears to be properly set up, according to the guidelines on this page.
The problem is when I pull up on the bar, the strings don't return perfectly to pitch. *They're "in tune" but not perfectly in tune, and that's bad.
Anyone else have similar experiences or advice? *I'd appreciate your replies. *Thanks!
Old 03-18-2001, 01:18 PM
Vaibanez  is offline
Posts: 813  -  iTrader: (5)
Czar,
If what you say is true, that the setup looks right, I'd look at the trem angle again. I have all my Ibanez guitars set so the trem lies at a slight negative angle (back of the trem lower than the pivot point). Also...make sure you're not following the Ibanez paperwork that came with your guitar that says to install your springs in a "V" formation. Use the strait formation for even pull on the trem.
As a side note, new, unused springs can be tempermental. I let guitars sit for a day or so with the trem depressed. I used my old nylon army belt to hold the bar down. This lets the springs get stretched out and works to break them in faster.
Your mileage may vary...
J>
Old 03-18-2001, 01:29 PM
jhczar  is offline
Jimm,
Thanks for your reply! *I'll try your suggestions. *
I also just found serveral posts under the FAQ about Trem set screws. *Gonna check that out too.
Thanks again!
Closed Thread
edge trem, ibanez guitars
