Go Back   Jemsite > Guitars and Gear > Other Ibanez Guitars
Other Ibanez Guitars Discussion about other Ibanez 6-string Guitars not covered in the above topics.
Old 09-25-2007, 07:50 PM
Ki swordsman Ki swordsman is offline
Posts: 1,507  -  iTrader: (0)
Re: Edge3 Replacement Tremolo
you're in luck! i came across the very pics you are looking for!!
here's where you can find them..
go to the first page of this thread,
go down a bit.
  #32
Old 09-25-2007, 09:40 PM
rty13ibz98 rty13ibz98 is offline
Posts: 1,555  -  iTrader: (25)
Originally Posted by nuno View Post
are you sure it was an EdgePro II? or more probably a Lo-TRS? cause the Schaller doesn't fit into an EdgePro-II (and EdgePro) cavity. or, better, it fits actually, but its knives don't fit the posts, look this:
Schaller into Edge-Pro II cavity: trem fits, posts don't.
wish i had pics, but the guitar was for a student of mine that bought an rgt42 body/neck off **** and i used spare parts for it. i was going to originally use a jackson jt-580 as it is essential the lo-trs, but it didn't work. too long. the floyd rose II was a direct drop. the posts aren't really a problem as they are cut in the "v" for the pivot. that made it possible for the knife edges to seat in the post.
rich
  #33
Old 09-26-2007, 01:51 AM
slash_88 slash_88 is offline
Posts: 110  -  iTrader: (0)
if u want good lisc trem for a swap with an edge pro 2, you can go get a gotoh. the gotoh i got fit right into mi jem555 routing.
  #34
Old 09-26-2007, 03:33 AM
nuno nuno is offline
Posts: 5,022  -  iTrader: (0)
could you plz post a pic of it?
  #35
Old 09-26-2007, 03:48 AM
thrill74 thrill74 is offline
Posts: 32  -  iTrader: (1)
I would like to see also.
  #36
Old 10-03-2007, 01:00 PM
Guitarmiester Guitarmiester is offline
Posts: 321  -  iTrader: (2)
Originally Posted by digitalsubstance View Post
For an RG350MDX, what would be a straight swap?
A Floyd Rose Pro will drop right in.
  #37
Old 10-03-2007, 01:01 PM
again...
*USELESS TOPIC WITHOUT PICS!*
  #38
Old 10-03-2007, 07:30 PM
LonePhantom LonePhantom is offline
Posts: 2,348  -  iTrader: (3)
I hope Chef21 doesn't mind me posting his pic here, but that guitar on the right is his RG350 that originally came with an Edge III. He directly replaced it with an OFR, there's a thread around here some where about it, and I'm pretty sure it was a direct fit for him.
  #39
Old 10-04-2007, 01:25 AM
Yeah that thread is here:
http://www.jemsite.com/forums/showthread.php?t=41770
And it's a licensed floyd all the way. Looks like a decent fit though
  #40
Old 10-04-2007, 01:28 PM
there are signs telling me that Chef21's is a pre-03 RG, i.e. Lo-TRS, not Edge-III. in fact, the "new" trem he put in the Lo-TRS place is one of those licenseds with wide wings, not a Floyd-direct licensed (narrow wings) like the Schaller or the Gotoh. i tried to put a Schaller in an Edge-III cavity and it did barely fit in width. now, a wide-winged licensed wouldn't. check this pic:
now look at these pics, it's an Edge-III cavity, and look how narrower in comparison with Lo-TRS's, keep the pickups width or pickups' screws as a reference:
and look at the back of the cavity, they look different in the spring block's area:
(see slanted walls and routing on the bass strings side)
(see square walls, and no routing on the bass strings side)
also, see how the tail's cavity is shorter than the baseplate cavity on the Edge-III:
in comparison with Lo-TRS's which has a tail cavity the same lenght of the baseplate cavity:
i may be wrong, but those cavities are different, and i can assure you that a wide-winged licensed WON'T fit the Edge-III cavity (unless you set it so high it stucks out of the cavity...). :
  #41
Old 10-04-2007, 01:33 PM
looking this pic better, it seems like the trem's sitting above the guitar's top level, not inside the cavity (also check the high action, by consequence):
  #42
Old 10-04-2007, 02:05 PM
jb4674's Avatar
jb4674 jb4674 is offline
Posts: 3,082  -  iTrader: (0)
Why is the action so high on it? I thought the top of the OFR should be parallel with the body.
Jimmy
  #43
Old 10-05-2007, 05:51 AM
because the trem's baseplate is sitting ON the top of the guitar, rather than resting flush into it, as it's supposed to be.
  #44
Old 10-05-2007, 07:50 AM
some neck shimming could fix that..
  #45
Old 10-06-2007, 12:22 AM
Chritar Chritar is offline
Posts: 227  -  iTrader: (0)
why not screw in the studs...would that not lower it?
Bookmarks
base plate, floyd rose, floyd rose pro, ibanez dealer, lopro trem, neck shim, pro edge, schaller trem, string lock
I need to find replacement tremolo studs for a Lo-TRS II, help! arilr Other Ibanez Guitars 2 07-30-2006 07:48 PM
Broken ZR tremolo... Is this common?? FastRedPonyCar Other Ibanez Guitars 16 06-01-2006 05:50 PM
S470DX, broken tremolo :( Steve069 Other Ibanez Guitars 10 05-16-2006 04:50 PM
Just a question... - about Tremolo Bridge Height Adjustment armindo__dias Tech: Setup, Repairs and Mods 2 11-03-2001 01:20 AM
Lo-pro Edge tremolo - replacement for 555 kylemac Gear and Equipment 7 07-24-2001 07:41 PM
Sitemap:1 2 3 4 5 6 7
