Go Back   Jemsite > Guitars and Gear > Other Ibanez Guitars
Other Ibanez Guitars Discussion about other Ibanez 6-string Guitars not covered in the above topics.
Old 07-20-2008, 11:48 PM
LonePhantom LonePhantom is offline
Posts: 2,348  -  iTrader: (3)
Re: Edge3 Replacement Tremolo
That's interesting, a number of people have said that the Edge Pro DID fit the Edge III cavity.
  #62
Old 07-21-2008, 04:56 AM
nuno nuno is offline
Posts: 5,022  -  iTrader: (0)
Originally Posted by Ryan350DX View Post
Deep, The Edge Pro doesn't retrofit the Edge III cavity, your best bet is the Original Floyd Rose.
the EdgePro DOES retrofit the Edge-III:
while the Floyd Rose (and Schaller Floyd as well) does NOT retrofit:
(check the wrong knife-to-post relationship)
  #63
Old 07-21-2008, 05:11 AM
i had the chance to make some trem-to-cavity fitting experiment lately and i ended up with the following results:
• Edge/LoPro trem on EdgePro/EdgePro II cavity: NO
• Edge/LoPro trem on Edge-III: cavity: NO
• EdgePro/EdgePro II trem on Edge/LoPro cavity: YES
• EdgePro/EdgePro II trem on Edge-III cavity: YES
• Floyd Rose/Schaller trem on EdgePro/EdgePro II cavity: NO
• Floyd Rose/Schaller trem on Edge-III cavity: NO
check pics HERE. sorry, italian only, but pics pretty much explain themselves
  #64
Old 07-21-2008, 11:20 AM
Ryan350DX Ryan350DX is offline
Posts: 137  -  iTrader: (0)
Has the Edge III cavity changed over the years? or has it remainded the same?
  #65
Old 07-21-2008, 06:42 PM
Deepsquirrel Deepsquirrel is offline
Posts: 7  -  iTrader: (0)
I won't be needed to put a new tremolo in after all
Managed to get a preowned Prestige RG1570 (edge pro already in there obviously) for £215, only around £50 more than i would have ended up paying for an OFR or an edge pro anyway! (replacement stuff is more expensive over here)
  #66
Old 08-26-2008, 04:02 AM
aj_foes aj_foes is offline
Posts: 100  -  iTrader: (0)
I did some Google-translating for a bit, and, thanks to Google, here's nuno's Italian trem-swap guide, translated into English. (well, pretty much..)
http://translate.google.com.my/trans...3DIxX%26sa%3DG
BTW, nuno, thanks a lot dude! Not everyone are able to experiment all this trem swapping thing and this page is making things a lot clearer to peeps! Cheers!
Bookmarks
base plate, floyd rose, floyd rose pro, ibanez dealer, lopro trem, neck shim, pro edge, schaller trem, string lock
I need to find replacement tremolo studs for a Lo-TRS II, help! arilr Other Ibanez Guitars 2 07-30-2006 07:48 PM
Broken ZR tremolo... Is this common?? FastRedPonyCar Other Ibanez Guitars 16 06-01-2006 05:50 PM
S470DX, broken tremolo :( Steve069 Other Ibanez Guitars 10 05-16-2006 04:50 PM
Just a question... - about Tremolo Bridge Height Adjustment armindo__dias Tech: Setup, Repairs and Mods 2 11-03-2001 01:20 AM
Lo-pro Edge tremolo - replacement for 555 kylemac Gear and Equipment 7 07-24-2001 07:41 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
