Sponsor Us
About Us
Community Blog
Other Ibanez Guitars
Edge3 Replacement Tremolo
Search
Today's Posts
Discussion about other Ibanez 6-string Guitars not covered in the above topics.
Registered Members don't see these ads.
Register now
it's free!
Page 1 of 5
09-18-2007, 02:22 PM
digitalsubstance
Guest
Posts: 26 - iTrader: (
I have an Edge3 Tremolo on one of my guitars and I want to replace it with something else. It's horrible and is tarnished and never stays in tune. I don't really want to shell out on another OFR, but I was thinking a really good licensed
Floyd Rose
would be good. Can anybody reccommend me something?
Register now
it's free!
digitalsubstance
Find all posts by digitalsubstance
09-18-2007, 05:55 PM
Dee
Posts: 8,471 - iTrader: (
Re: Edge3 Replacement Tremolo
Schaller, Gotoh, Ping. Those are 3 of the makes that I would look at.
Dee
Find all posts by Dee
09-18-2007, 10:17 PM
LonePhantom
Posts: 2,348 - iTrader: (
Gotoh all the way.
LonePhantom
Find all posts by LonePhantom
09-19-2007, 03:42 AM
thrill74
Posts: 32 - iTrader: (
Gotoh or OFR hands down.
thrill74
Find all posts by thrill74
09-19-2007, 03:56 AM
nuno
Posts: 5,022 - iTrader: (
you must know first that ANY other trems except the Edge-Pro and Edge-Pro II will require routing works on the cavity to accomodate.
nuno
Visit nuno's homepage!
Find all posts by nuno
09-19-2007, 05:56 AM
slash_88
Posts: 110 - iTrader: (
gotoh will fit the edge 3 rout. its affordable compared to the rest of the brands.
slash_88
Find all posts by slash_88
09-19-2007, 06:35 AM
nuno
slash_88
you tried it? i did, and it didn't fit.
nuno
09-19-2007, 08:26 PM
LonePhantom
If it doesn't fit I'm sure there's just a little bit of sanding (or dremmel to speed up the process if you have one) around the cavity to fix it.
LonePhantom
09-19-2007, 09:25 PM
thrill74
I've done an OFR replacement to a 350EX that was a direct drop in. Same thing with an LTD M-400, but that's a different story all together.
thrill74
09-19-2007, 10:11 PM
Salamander In The Sun
Posts: 874 - iTrader: (
PING
Hands down, the best OFR copy out there. In fact, it's the only LFR to bear the Floyd Rose logo on it's baseplate.
I can attest to it's durability, I own one.
Find all posts by Salamander In The Sun
09-19-2007, 11:21 PM
slash_88
isn't the edge 3 rout the same as the edge pro 11? because your earlier post said the edge pro 2 and edge pro doesnt need routing work to retrofit an edge 3 rout. so im assuming the edge pro 2 and edge 3 sizes are the same. and my gotoh i used retrofitted mi edge pro 11 rout easily. so it should go in unless the edge 3 rout is smaller.
slash_88
09-20-2007, 03:52 AM
nuno
slash_88
yep, but somehow you can't do vice versa. unluckily i forgot to take pics when i tried to fit a Gotoh in an Edge-III rout but i took one with a Schaller Floyd, which is exactly the same shape and dimensions of the Original Floyd and the Gotoh as well. it
would
fit dimensions-wise, but the post holes are moved too backward for the Gotoh knives to fit in. take a look...
Edge-Pro into an Edge-III rout: it fits.
Schaller (Gotoh) Floyd into an Edge-III rout: it doesn't fit.
nuno
09-20-2007, 03:55 AM
nuno
thrill74
what year? i.e. what trem there was in?
nuno
09-20-2007, 04:34 AM
slash_88
ar i see thanks for the insight nuno. interesting and edge pro can fit and edge 3 rout. by the way nuno is an edge able to fit a edge pro rout? just curious to know.
slash_88
09-20-2007, 06:19 AM
nuno
slash_88
unluckily no. the back side of the "wings" would rock against the cavity, and the
string lock
screws as well. take a look...
Edge into Edge-Pro cavity (JS1200CA): no fit
same thing with the Lo-Pro:
Lo-Pro into Edge-Pro cavity (JEM7VSBL): no fit
06:25 AM
nuno
Page 1 of 5
Bookmarks
Digg
del.icio.us
StumbleUpon
Google
base plate
floyd rose
floyd rose pro
ibanez dealer
lopro trem
neck shim
pro edge
schaller trem
string lock
I need to find replacement tremolo studs for a Lo-TRS II, help!
Broken ZR tremolo... Is this common??
S470DX, broken tremolo :(
Just a question... - about Tremolo Bridge Height Adjustment
Lo-pro Edge tremolo - replacement for 555
arilr
07:48 PM
FastRedPonyCar
05:50 PM
Steve069
04:50 PM
armindo__dias
Tech: Setup, Repairs and Mods
01:20 AM
kylemac
Gear and Equipment
07:41 PM
07:14 PM
