Old 09-13-2005, 01:26 PM
rchip  is offline
Posts: 25  -  iTrader: (0)
F spaced pickups for an RG?
Hey there, just a quick question. I'm thinking of buying an RG550, and putting some evolutions in it. Which pups do i use? Are any F spaced or standard? Thanks alot.
Old 09-13-2005, 01:34 PM
j.arledge  is offline
Posts: 1,804  -  iTrader: (30)
Re: F spaced pickups for an RG?
http://www.jemsite.com/forums/showthread.php?t=39688
Old 09-13-2005, 02:00 PM
rchip  is offline
Thanks, so is that right that I need two F spaced evos, one for bridge and one for neck?
Old 09-13-2005, 02:06 PM
bluealien  is offline
Posts: 959  -  iTrader: (0)
Yes, If you have the Edge Trem, you need F spaced.
Old 09-13-2005, 06:40 PM
Originally Posted by MicJustMic
Technically, you never really need F-spaced pups.
Cosmetically they look better because the poles line up, but in my own testing, both with meters and with my ears, I've found you don't get any better balance with the strings than with a regular spaced pickup.
Even with the regular spaced, the string falls well within the magnetic field of the pole, and the string disrupts the field in the exact same way when it's vibrating as with the F-spaced pup.
It just looks better having the pole right under the string . . . that's about the only benefit. If you are buying pups, go for the F-spaced, they cost the same, but if you already have regular spaced, don't fret (pun not intended), you're not losing anything by using it.
Mic
qoute
yep, he is right, f-spacing isn't nessicary, it doesn't affect your sound , i have played with non f-spaced pickups in an ibanez and then had f-spaced in the same ibanez later and there was no difference in sound quality
Old 09-13-2005, 07:21 PM
Umm, I had a issue with my old Charvel and put in a Dimazio Humbucker from Hell & Fred, that was not F-spaced, and didnt line up at all, the tone really sucked and seemed to have dead spots, I had them get me a F spaced which was much better and I noticed a difference, but then it was a Charvel not a Ibanez.... Then played my first Jem, and sold both my Charvels to get one. Nothing like a real JEM.
This was before I new of the whole F space issue.
Old 09-13-2005, 08:12 PM
Gex  is offline
Posts: 962  -  iTrader: (1)
The strings get narrower towards the neck, on my RG550s a F spaced bridge and a standard neck humbucker work great, poles line up great.
edge trem, neck humbucker, spaced pickup, standard neck
What pickups for my Ibanez RG 550? Mid and Neck? DotNetTim Other Ibanez Guitars (including Premiums) 21 06-06-2005 04:14 PM
FS : ibanez RG USA CUSTOM 1991 UCEW1FM fredperry Classified Ads: Guitars and Gear 6 05-09-2005 06:00 PM
How can I define my RG is 470 or 570? Dissection Other Ibanez Guitars (including Premiums) 6 03-08-2005 03:00 PM
FS/FT: Ibanez RG 550 Mirror Pickguard Fully loaded with Pots and Pickups parker_fly Classified Ads: Guitars and Gear 2 03-01-2005 11:31 PM
direct body pickups vs pickguard pickups? jsdetrait Gear and Equipment 3 06-25-2002 01:18 PM
