Old 11-16-2007, 06:15 PM
jt93  is offline
Posts: 20  -  iTrader: (0)
Question
gax tuner replacement quiestion
i picked up a gax last nite, and it plays nice, but i want to replace the tuners. is there anything special i need to know / look for?
thanks
Old 11-23-2007, 05:17 AM
mccon.mark  is offline
Posts: 17  -  iTrader: (0)
Re: gax tuner replacement quiestion
iv got a gax70 and i changed the tuners for grovers... the only thing is that the grovers had a little screw that held them in place while the ibanez ones had little bits of metal that held them in place. i just gently drilled a small hole at each tuner after marking it with the grovers test fitted.
as far as i know, most tuners will need this.
Old 11-28-2007, 01:26 PM
jairic  is offline
Posts: 308  -  iTrader: (8)
mccon.mark is right, there is the very light modification you may need to do, but it will be worth it. Planet waves make some tuners worth looking into as far as mild upgrades go
Old 11-28-2007, 02:14 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Smile
Both of you are incorrect and obviously haven't researched tuners enough.
Sperzel Tuners
http://www.stewmac.com/shop/Tuners/G...s.html#details
Schaller Tuners
Jimmy
Old 11-28-2007, 04:15 PM
sorry, the grovers i have defo were an easy swap, hav spapped those out on a lespaul also... MOST aftermarket tuners are similar.
Old 11-28-2007, 04:25 PM
jb4674  is offline
Reviews: 6
Well, considering you have to do no modifications to install either the sperzels or the schallers, that's the route I would go. The second plus is that both of them are locking tuners and will be better than any grovers by reducing slippage on the strings every time you bend them.
Jimmy
Old 12-03-2007, 08:08 PM
jt93  is offline
what is the post diameter on the stock tuners? i searched ibanez and google, but could not find this info anywhere? most tuners are 10mm, and i would rather not have to drill out the holes.
tnx
i really like the stienberg gearless. 40:1 ratio
locking tuners, planet waves, schaller tuners, sperzel tuners
Replacing D tuner in ZR tanpsi Other Ibanez Guitars (including Premiums) 2 09-15-2007 10:11 PM
tuner pedal quuestionn JasonMalmsteen Gear and Equipment 8 04-08-2007 11:13 PM
Best way to send a clean signal to tuner?? ChrisReedSmith Gear and Equipment 6 10-03-2004 12:26 PM
Which tuner? Drache713 Gear and Equipment 4 05-11-2003 08:26 PM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear and Equipment 5 02-13-2002 10:55 PM
