Old 02-13-2007, 09:39 PM
lalosd  is offline
Posts: 6  -  iTrader: (0)
Question
Help
hi , i usually dont post, cause my english is not pretty good, but i read a lot in this forum and i have learned a lot about ibanez and guitars in general, but right now that its hard to get a guitar cause most of them are not in stock, i need help, what do you think would be better, an rga121 with emgs, or should i just go for the rgt6exfx that already comes with emgs?, i will tune it down to B, and im scare that something could happen to the neck of the rgt.
Old 02-13-2007, 10:25 PM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
Re: Help
I personally would get the RGA.
"Generally" The Japanese made guitars (prestige) are better and more expensive than the Korean made guitars.
Why are you scared about the neck?
Old 02-14-2007, 12:00 AM
Ironjose  is offline
Posts: 1,057  -  iTrader: (0)
Re: Help
if you get some heavy gauge strings and tuned them to B it should be no problem coz its like you got some 9's and tuned them to standard tunning... so get scared if you are scared about the neck not holding...
Old 02-14-2007, 12:12 AM
studentofshred  is offline
Posts: 145  -  iTrader: (0)
Re: Help
By the way, your english is alot better then alot of native speakers that I talk to.
Old 02-15-2007, 05:55 PM
lalosd  is offline
Re: Help
thanx, i was scared cause i thought that heavy gauge strings could make the neck look like a bow even if its tuned in B, i had an rg2550 it was tuned to B too, but it was set up by a pro in california but now im back in Mexico , heres a picture of the rg2550 customized.
Old 02-15-2007, 08:15 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Re: Help
Yeah, just use more periods
gauge strings, heavy gauge strings
