Help me choose a trem for custom body
04-01-2008, 10:45 AM
wizard75wizard
Posts: 13 - iTrader: (
I'm in the proccess of making a new RG body, I just know my Edge and
edge pros
, what do you recommend?
Iwould like to change to the newer trems, hence I got to specify the trem type. I;m kind confused between Edge pro, Edge III, II? I
Thanks
wizard75wizard
Find all posts by wizard75wizard
04-01-2008, 12:05 PM
nuno
Posts: 4,725 - iTrader: (
Re: Help me choose a trem for custom body
forget about the EdgePro II and Edge-III. all the rest is up to you. just consider that the bearing-ball trems have pretty different feel than the traditional Floyds, probably due to the ZPS, and they also are very precise and they virtually never wear out (they don't have knives).
nuno
Visit nuno's homepage!
Find all posts by nuno
04-01-2008, 12:08 PM
Crazy_Guitar
Posts: 1,319 - iTrader: (
Reviews: 4
Edge and Lo-
Pro Edge
are excellent trems!
Edge Pro is a derivate of the Lo-Pro Edge. Pay attention to the trem posts!
Then there are the ZR and the brand new
Edge Zero
ZR is a completely different approach to a trem (uses ball bearings instead of a knife edge).
Edge Zero is the mix between ZR and Edge: uses Edge's knife edge and ZR design and spring block.
The feeling of the Edge and Lo-Pro Edge is just fantastic: very solid and stable.
I have never tried the Edge Pro with the correct posts, so, I will not say anything.
The ZR is very smooth. I have never tried it without the "zero point system".
Never seen the Edge Zero in person...
Crazy_Guitar
Visit Crazy_Guitar's homepage!
Find all posts by Crazy_Guitar
04-01-2008, 12:41 PM
nuno
IMO the EdgePro is as smooth and stable as the old bros Edge/LoPro. and the ZR with the ZPS feels a bit stiffer then all from the Edge family, more like an OFR.
nuno
04-01-2008, 08:31 PM
wizard75wizard
so is edge III and II considered to be comparible to TRS, in another words Edge pro would be above these too?
wizard75wizard
04-02-2008, 03:42 AM
nuno
wizard75wizard
yes, all these three are definitely below the EdgePro. IMO, in order of quality:
1) Edge, LoPro Edge, EdgePro, ZR, EdgeZero, SynchroniZR
2) EdgePro-II, Edge-III, Lo-TRS II
3) TRS101, Lo-TRS
4) Single Locking
my 2 cents
nuno
04-02-2008, 09:39 AM
wizard75wizard
nuno
3) TRS101, Lo-TRS
4) Single Locking
my 2 cents
Thanks alot, this is helpfull
wizard75wizard
04-02-2008, 11:22 AM
Crazy_Guitar
Reviews: 4
nuno
3) TRS101, Lo-TRS
4) Single Locking
my 2 cents
+1
I would also add to #1 the OFR, OFR Pro, Gotoh and Schaller trems (locking) and Wilkinson (non-locking - use with
locking tuners
Go for option #1.
Crazy_Guitar
04-02-2008, 11:31 AM
chaos731
Posts: 489 - iTrader: (
If you're going for a true Ibanez-ish feel, I would say I'm terribly partial to the original
Edge trems
in PC finish. Purty. Strong. Stable.
Just my 37 cents.
chaos731
Find all posts by chaos731
04-02-2008, 12:09 PM
nuno
wizard75wizard
Crazy_Guitar
I would also add to #1 the OFR, OFR Pro, Gotoh and Schaller and Wilkinson.
agree. i actually was referring for some reasons to Ibanez trems only. gotta kick Ibanez off my head one day
nuno
04-02-2008, 12:25 PM
Matheau
Posts: 206 - iTrader: (
I wouldn't recommend the ZR if you have never played them before and have only played with Edges. They do feel different, and whether you like them better or worse is going to be a preference thing. So if you are thinking about one of those, I would at least go and try a guitar with one in it beforehand.
Matheau
Find all posts by Matheau
edge pros
edge trem
edge trems
edge zero
ibanez trem
locking tuners
pro edge
schaller trem
how to intonate a zr trem
what trem is on the rusty cooley
what happens to your body before you die
where is the ibanez japan custom shop
will prestige neck fit rg body?
FS: Jem copy body - UK
Serratus
06:12 AM
FS: RG550 Project Body and RG Copy Body
t1r12003
11:49 AM
RG body and trem
BlueGlow
Tech: Setup, Repairs and Mods
12:41 AM
RG 550 Edge Trem work in floyd route new body?
IndyTim
02:28 AM
Can't get edge trem in adjustment - always too high, too low
bduersch
12:37 AM
07:02 AM
