Old 08-03-2006, 03:48 PM
PatrickSimsCustomShopUSA  is offline
Posts: 1,166  -  iTrader: (0)
Help needed with an RG 340
Does a 340 have the exact same shape as the rest of the RG's? Does the 340 have the sharp lower horn? Somebody I know wants to sell theres to me for a good deal but I'm not sure what they look like.....and I can't find any pictures on it. Anybody know anything about them? Type of neck, trem, body shape, etc....
Thanks!!
Old 08-03-2006, 03:54 PM
Re: Help needed with an RG 340
Also, it is a square neck joint guitar. I think the body is different. But could I use the neck on it on like a square neck joint 570? I just don't know much about them. I know most square neck joint necks will work in any other square neck joint, but I just didn't know if the 340 neck would work in 470's, 550's, 570's, etc....
Anybody know?
Old 08-03-2006, 03:56 PM
The neck is 22 frets......any problem with putting a 22 fret neck on a RG 470 body that was originally made for 24?
Thanks!
Old 08-03-2006, 04:14 PM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
Thanks!
Yes, it will not intonate .
Regards
André
Old 08-03-2006, 04:19 PM
Demiurge  is offline
Posts: 883  -  iTrader: (7)
Try www.ibanezregister.com- they have pictures of almost every model.
The 340 on there has very rounded horns, but the pic is of a refinish project, so you never know if they took off some wood there.
The 22/24 fret thing is best explained by this: it's not the number of frets, but the scale length and therefore whether the extra 2 frets are fingerboard extension or not.
Old 08-03-2006, 04:29 PM
Thanks! I don't see the 340 on there tho, under 340 it says "0 files"
Old 08-03-2006, 04:32 PM
So the 22 fret neck wouldn't work on a RG guitar b/c of the scale, correct? Are these guitars worth anything? Are they desirable? Would it be worth swirling or putting a custom paint job on.....
Old 08-03-2006, 05:23 PM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
i would say no, but you never know...
Old 08-03-2006, 05:53 PM
Demiurge  is offline
It looks like they're updating the site. On the left-hand bar, just to to "old gallery," the select "The Guitars" and scroll through to the RG section. For some reason the site doesn't change URL's so I couldn't get a direct link for you.
body shape, fret neck, neck joint
Ibanez RG 770's and 750's information needed Amy Other Ibanez Guitars (including Premiums) 36 06-09-2007 02:15 AM
Unidentified RG - help needed gruel Other Ibanez Guitars (including Premiums) 18 09-04-2005 12:42 PM
Locating the neck pocket position on a RG, help needed Swirly Tech: Setup, Repairs and Mods 0 12-07-2003 07:50 PM
Help needed on choice of woods for my RG project... Swirly Tech: Setup, Repairs and Mods 13 09-26-2003 03:00 PM
WIRING HELP NEEDED - wiring on RG aerocol Tech: Setup, Repairs and Mods 6 07-17-2001 02:02 PM
