How to get trem bar to stay in place?
05-17-2005, 07:04 PM
ElectriK
Posts: 150 - iTrader: (
how can i keep my trem bar on my RG570 with an edge to stay in 1 spot, it keeps sliding down and when i try to get it back up i always hit the volume knob. Is there a way to secure it in place?
ElectriK
Find all posts by ElectriK
05-17-2005, 07:22 PM
Andelusion
Posts: 1,373 - iTrader: (
Re: How to get trem bar to stay in place?
http://www.jemsite.com/tech/t_3other.htm#tremarmrot
Andelusion
Find all posts by Andelusion
05-17-2005, 07:30 PM
ElectriK
is there a way without using nail polish?
ElectriK
05-17-2005, 07:47 PM
Andelusion
Wrap something like sticky tape around it.
What's wrong with using nail polish? It works well!
Andelusion
05-17-2005, 07:58 PM
ElectriK
i dont have any lol. and if i put nail polish, would it make it so that i coulnt remove the bar if i pulled on it?
ElectriK
05-18-2005, 01:26 PM
evil_k666
Posts: 112 - iTrader: (
you put it under the nylon washers not on top of them, so jeah, you will still be able to remove the trembar, yet it might be a bit harder then before (that's actually what you wanted)
evil_k666
Find all posts by evil_k666
05-18-2005, 04:16 PM
markg5150
Posts: 2,361 - iTrader: (
I've found that nail polish (my wife's by the way!!!) doesn't last very long
PTFE tape works ok, but new bushes or tightening the nut from inside the trem cavity is best.
As usual for any tech issues check out ibanezrules.com !!!!!!!!!!
markg5150
Find all posts by markg5150
05-18-2005, 05:24 PM
sepsis311
Posts: 289 - iTrader: (
do the
trem arm
mod if its possible. use the
floyd trem
in the edge.
sepsis311
Find all posts by sepsis311
05-19-2005, 01:25 AM
evil_k666
i'm using nail polish and it works best for me...
so far in 2 years i put on 2 coats... this way i save money and get the same results without any mod or tightening the nut .....
evil_k666
05-19-2005, 01:48 AM
rory
Posts: 102 - iTrader: (
Nail polish wears off. There's another trick that I use: If you have any ziploc bags or D'Addario string pouches, cut a circle about the size of a quarter. Pull the bar out. Center the plastic over the bar holder and insert the bar into the plastic. It goes in tough, but it won't go anywhere.
rory
Find all posts by rory
05-19-2005, 02:44 PM
CrossingStar
Posts: 1,046 - iTrader: (
Nail polish was OK with me but lately I do what rory does. I cut out circles from plastic grocery bags (really thin ones) & lay that over the trem bar hole before the trem is in, then push the bar into the hole along with the plastic. It pretty much works only one time because it shreds the plastic up. So I just make a bunch of these little plastic circles at once.
CrossingStar
Find all posts by CrossingStar
floyd trem
trem arm
how to stay on relic
does the JEM 7 trem stay in position?
what trem is on the rusty cooley
How to block ibanez trem
is my edge trem bar in all the way
Replacement of your trem arm - "tutorial" with pictures
Jammy
Tech: Setup, Repairs and Mods
93
05-16-2009
06:56 AM
Best and easiest place to get trem parts?
sawzall
09:10 PM
wheres the cheapest place for a trem arm holder?
elwood hitch
03:04 PM
Trem angle
wangbar
06:37 PM
Repairing trem knife edges - Trem on my JS1000 will not retu
Jason Stone
Archived Topics and Common Questions - GO HERE FIRST
09:24 PM
01:28 AM
