How to tell if a neck is made in Japan?
03-04-2008, 07:15 PM
GuitarEvan07
Posts: 666 - iTrader: (
Hey guys, I just bought an Ibanez RG neck from a guy here on the forum. The back of the neck is sanded down, along with the back of the headstock, so I don't know where it was made(cause I can't see the serial number). It was made in '97. Only way I know that is cause its stamped on the back of back of the neck(the part that connects to the body).
The reason I ask is because I know many of the RG series back then were made in Japan. Was this one? Also, I dont know what model it was.
FYI: It has grey
shark tooth inlays
Rosewood fingerboard
. Black headstock, says "RG series" on logo(obviously)
GuitarEvan07
Find all posts by GuitarEvan07
03-04-2008, 07:21 PM
rty13ibz98
Posts: 1,811 - iTrader: (
34
Re: How to tell if a neck is made in Japan?
does it feel like a wizard 1 or 2? since your thinking its a 97 and with sharksteeth on an rg, i would venture to say that it's a korean neck from a lower end dx model.
rich
rty13ibz98
Visit rty13ibz98's homepage!
Find all posts by rty13ibz98
03-04-2008, 08:42 PM
albee1952
Posts: 784 - iTrader: (
Another tell is what holes are there for tuners. If each has 2 un-threaded holes and no offset screw hole, likely it had screw-less tuners which makes it probably Korean. If each tuner has a single offset screw hole, that means
Gotoh tuners
and probably Japanese. This is not 100% proof but applies to most RG's.
albee1952
Find all posts by albee1952
03-04-2008, 08:51 PM
rty13ibz98
34
albee1952
Another tell is what holes are there for tuners. If each has 2 un-threaded holes and no offset screw hole, likely it had screw-less tuners which makes it probably Korean. If each tuner has a single offset screw hole, that means Gotoh tuners and probably Japanese. This is not 100% proof but applies to most RG's.
good point!!
rich
rty13ibz98
03-05-2008, 10:01 AM
TAorama
Posts: 1,762 - iTrader: (
If it's date stamped on the back of the neck heel, it's probably NOT Japanese. I've seen a lot of Korean W2's stamped like that, but no original Wizards.
TAorama
Find all posts by TAorama
03-05-2008, 12:28 PM
jkahrs
Posts: 477 - iTrader: (
See what
truss rod adjustment
nut it has. I've never seen a Japanese model that didn't have the brass hex nut. All the others, korean, Indo, Chino, etc, I've worked on seem to have the allen head hex socket you use an
allen wrench
to adjust. --Jason
jkahrs
Find all posts by jkahrs
03-06-2008, 10:27 AM
gpenguins
Posts: 944 - iTrader: (
63
I think the tuner holes are the quickest way to tell, although possibly quicker is if the headstock logo is mirrored or not. From what I've seen, until the last couple of years, the Jap ones always had mirrored logos with "RG Series" and the Korean and Indo ones didn't. I think so anyway.
gpenguins
Find all posts by gpenguins
03-06-2008, 10:28 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
How about a picture of the neck?
Jimmy
jb4674
Find all posts by jb4674
03-06-2008, 10:38 AM
gpenguins
63
jb4674
Jimmy
Sure, make it easy on everyone...
gpenguins
allen wrench
black headstock
gotoh tuners
rod adjustment
rosewood fingerboard
shark tooth inlays
truss rod
how it's made godin
wheres pgm30 made
parker are they neck thru
what metal is edge 3 tremolo made out of
which Jacksons are made in Japan?
Painted neck? Sanded neck?
Drache713
Other 7-string Guitars
12:45 AM
problem!!!s520 japan made.
sera
03:54 PM
sera
01:11 PM
cutting an original neck to become an all access neck
Zeroleet
Tech: Setup, Repairs and Mods
32
05-05-2005
10:08 AM
Changing Vine inlay colors - things that make you go hmmmmmm
tomizm
34
04-13-2001
03:14 PM
07:32 AM
