Old 04-05-2008, 10:15 PM
badguitarist  is offline
Posts: 61  -  iTrader: (0)
I can not lower my pickup anymore!!! HELP!!
My guitar is a RG1570 with direct mounted pickups. My bridge pickup is a Steve Morse (DP200). Now it's too close to the strings, thus losing clarity and some sustaining. But I can not lower it anymore. I notice that it's thicker than my neck pickup and I think that's why it's closer to strings compared to the neck one. Is this a problem? How can I lower it?
Old 04-05-2008, 10:25 PM
moebius  is offline
Posts: 2,043  -  iTrader: (0)
Re: I can not lower my pickup anymore!!! HELP!!
Is there any wood or material underneath the pickup between the body?
Old 04-05-2008, 10:37 PM
Yeah there's some kind of foam. It's soft
Old 04-05-2008, 11:44 PM
callen3615  is offline
Posts: 1,412  -  iTrader: (7)
i would carefully remove that stuff. is it like trem cavity dressing?
Old 04-06-2008, 01:17 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Or put a thin shim under the tail end of the neck which would call for raising the bridge slightly to keep the same action.
Old 04-06-2008, 01:22 AM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
under the foam is wood; it needs to be dremeled out.........I had to doit to effectively use many Dimarzio`s I've tried in my 1570.....
dremel it out and just use a black sharpie to recolor the cavity.
Old 04-06-2008, 01:07 PM
losgatosrg350dx  is offline
Posts: 848  -  iTrader: (0)
ive dremeled my carvins, my jacksons and its no big deal
just dont get it too hot, do it in steps the wood is hard
Old 04-06-2008, 02:33 PM
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
Do you know how to soften hard wood?
Old 04-09-2008, 02:13 AM
Mindcrime1204  is offline
Posts: 63  -  iTrader: (0)
Ya...show it a picture of some ugly old lady naked.
bridge pickup, direct mounted pickups, mounted pickups, neck pickup, steve morse
HELP REQUIRED - Total novice trying to fit a pickup!!!!! SPENSPUMA Pickups & wiring 14 09-19-2006 12:24 AM
looking for neck pickup maliciousteve Pickups & wiring 35 05-08-2006 11:56 AM
New Pickup For Strat bonehead189 Pickups & wiring 6 12-06-2005 09:57 PM
Can you lower the output of a pickup ? - Voltage reduction ? 6828 Tech: Setup, Repairs and Mods 2 01-13-2002 04:03 AM
Stupid pickup question - What if there was no pickup... ashlock Tech: Setup, Repairs and Mods 3 07-06-2001 05:12 PM
