Old 09-02-2009, 01:50 AM
jrade  is offline
Posts: 101  -  iTrader: (0)
i realized my rg570ct has a small neck pocket crack should i just ignore it?
its on my 1995 rg570cttb very hard to see as the paint is dark and not noticable. does not look like it goes all the way through the wood just surface but could be going all the way through. its less then an inch closer to half an inch long from the fret board. i can only see it on one side and in the right light other wise not apparent. its a 15 year old guitar. should i have any worries or just ignore it unless it gets longer and bigger. will it probably get bigger or possibly not. where it is where the body wood is very thin before it curves out and gets very thick. it does not seem to want to go any further then just where its obviously weak at the pocket from being thin. it stops way before the mass of the body is and gets very thick. like a said like a half an inch long possibly less i am not using a ruler.
i will try to take pictures but from what i can tell even my canon xt camera cant even pick up on it as my ngd pictures dont show it. it really needs to be on the right angle and is still barely seen its so dark through the transparent layer and so small its less then a half an inch.
Old 09-02-2009, 02:14 AM
Homebake  is offline
Posts: 1,041  -  iTrader: (1)
Re: i realized my rg570ct has a small neck pocket crack should i just ignore it?
don't worry about it, about 90% of old ibanez guitars have it.
Old 09-02-2009, 07:39 AM
brianxtr  is offline
Posts: 1,642  -  iTrader: (8)
i had 50 ibz in the past and i have had 4 wich didnt...those were (almost) new,in some stores have the guitars these cracks!
Old 09-02-2009, 07:53 AM
Homebake  is offline
my rg2550z which i've had for about a year still doesn't have any finish cracks around the neck joint. i'm kind of waiting for the day when i'll see the first one.
Old 09-05-2009, 02:02 AM
jrade  is offline
so is this a fixable thing and as i dont need to worry about it when do i know when its time to fix it. once it has fallen apart or something?
i just want to know. when should i consider taking it to the luthier and getting it repaired. i love this guitar and dont want to let it in the future fall apart. so when should i repair this guitar. i understand its probably fine. but when do i know the crack has developed to a state i should get it fixed?
Old 09-05-2009, 02:57 AM
Ayrton  is offline
The crack is in the finish, forget about and enjoy the guitar.
Old 09-05-2009, 03:10 AM
jrade  is offline
i know your probably right. its just my first guitar. and i dont want anything to happen to it. so i am paranoid on maintaining it and preventing anything to happen. we all have felt this way right?
Old 09-07-2009, 12:04 AM
ELicari  is offline
Posts: 238  -  iTrader: (0)
Yeah its just the finish don`t worry about it.
crack, neck, neck pocket, neck pocket crack, rg570ct
New SV5470 including neck pocket crack! sbUK Other Ibanez Guitars (including Premiums) 9 08-24-2008 04:10 PM
Neck pocket too small greenermeanie Tech: Setup, Repairs and Mods 3 12-07-2007 11:43 AM
Neck pocket crack. Zoot JEM and Universe Guitars 27 01-11-2007 02:59 PM
Small crack in neck m0p Tech: Setup, Repairs and Mods 5 09-11-2006 09:56 AM
Stress crack on neck joint, or just a finish crack? m0p Tech: Setup, Repairs and Mods 6 11-09-2005 06:59 PM
