Old 01-03-2008, 01:12 PM
jkahrs  is offline
Posts: 477  -  iTrader: (6)
Re: Ibanez 540P/540PII owners?
That thing looks pretty nice. I may have to build something like it for myself! --Jason
Old 01-03-2008, 02:03 PM
gpenguins  is offline
Posts: 944  -  iTrader: (63)
Who do you think was going to paint mine if I decided to go that way?
Old 01-03-2008, 02:52 PM
sers  is offline
Posts: 252  -  iTrader: (0)
tnx to all... some day i`m going to have one of these
Old 01-03-2008, 03:34 PM
Jemmm  is offline
Posts: 426  -  iTrader: (0)
Those darn 540pii bodies.....were are they when you need 'm hey?
Would kill for Pii neck though (incl. toplock nut).
Old 01-03-2008, 03:46 PM
Canadian Mark  is offline
Posts: 435  -  iTrader: (1)
Good luck with the toplock nut! If you find a source, please let me know.
I had to buy a floyd rose R5 that was way too thick. I then had to have the back milled down by a machinist which ruined the plating. I couldn't find a chromer that could get black chrome to flow into the small crevasses, so I had to remove every bit of the nickel plating of the rest of the nut then get it hot-blued by a gunsmith. If you don't get all the nickel off, the bluing won't penetrate the metal on these spots, and the nickel will contrast very brightly.
Total cost for a nut (that isn't even cosmo black), WELL over $100.
Old 01-03-2008, 03:48 PM
Yeah, luckily mine had the nut on it. I actually have a custom made neck that takes the same width that I have a gold one on, but I'm not sure how thick it is. I'll have to check that when I get home.
Old 01-03-2008, 03:59 PM
Originally Posted by gpenguins View Post
Yeah, luckily mine had the nut on it. I actually have a custom made neck that takes the same width that I have a gold one on, but I'm not sure how thick it is. I'll have to check that when I get how.
Mine probably needed about 2mm shaved off the back. It would have resulted in the strings being pulled way sharp when fretting on the first couple of frets.
Old 01-03-2008, 04:37 PM
LonePhantom  is offline
Posts: 5,368  -  iTrader: (6)
Reviews: 98
Why didn't you just take the 2mm off the neck itself? As long as you are careful that would have been the easier option. Just food for thought there.
Old 01-03-2008, 04:45 PM
I was thinking of that, but I thought if something got screwed up, I would never find another PII neck. If something got screwed up on the nut, I could just call Warmoth and order another R5 nut for $30. Plus I'm still holding out hope that someday I will find a cosmo 45mm nut that will be a perfect fit (it's a long shot but you never know).
Old 01-03-2008, 04:56 PM
Jemmm  is offline
I once had opportunity to buy an 540Pii neck in very good state, but lacking toplock nut. I opted out for this same reason.
When I'm done with my 540Pvii I will probably build another 6 stringer 540pii body and take RGR or Reverse USA Custom necks to finish it off.
Old 01-03-2008, 05:06 PM
I would definitely consider a Pii with a wizard profile neck. I just love the neck on my Jem 7PBK.
By the way, are you close to finishing your 540Pvii? That looked like an awesome project when I saw it last.
Old 01-03-2008, 05:36 PM
Originally Posted by sers View Post
OH MY GOD!!!
I REALLE WANT ONE OF THIS BABES!!!
The Shape of the 540pII is perfect!!!
Congrast man!! Love the flames!!!
I agree with you regarding the shape. The Jackson & Charvel Demons are close, but they just don't seem to have all the right angles like the Ibanez's.
Old 01-05-2008, 02:08 PM
Gtr4000  is offline
Posts: 187  -  iTrader: (4)
No doubt you all have seen mine before
Old 01-07-2008, 09:40 AM
I never get tired of looking at 540P's
Old 01-12-2008, 11:31 AM
Sorry if this should be in the tech section, but I figure one of the 540p junkies would have the answer that I am looking for.
I'm just about finished shielding the cavities on my project and am ready to start wiring. Does anyone know how the original 540p's were wired? Does anyone have the diagram for a 2 humbercker with a 3 way toggle switch?
Thanks for all the help.
Ibanez & Vai timeline of events - working together jemsite Archived Topics and Common Questions - GO HERE FIRST 16 04-02-2009 03:38 PM
'Custom' Ibanez Shredder stuck in the 80s JEM and Universe Guitars 40 05-16-2007 03:01 PM
Ibanez catalogs - call for scans jemsite Other Ibanez Guitars (including Premiums) 82 03-27-2006 11:38 PM
FS:\ Ibanez HR Giger w/ Ibanez case NEW!!! rikkbeatty Classified Ads: Guitars and Gear 2 02-20-2006 02:17 PM
Ibanez Signature built by not Ibanez in the 80's? The Euphor JEM and Universe Guitars 3 06-29-2002 10:05 AM
