Old 08-12-2006, 10:05 PM
Clydefrog  is offline
Posts: 284  -  iTrader: (6)
Ibanez Edge trem bar replacement?
I have an RG565, made in 1990, so I assume it has an original Edge in it (though I cannot be sure, hence this thread).
The only bar I can find for it online simply says:
Ibanez Tremolo Bar for Edge or Edge II
Is there any way to be sure that it will fit what I have?
Old 08-12-2006, 10:10 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Re: Ibanez Edge trem bar replacement?
Just get the one with the 2 white nylon bushings and you're good to go.
And yes, the 565 did indeed have the original Edge.
Old 08-12-2006, 10:12 PM
-Rhaab  is offline
Posts: 479  -  iTrader: (0)
maybe a regular floyd rose bar will fit?
I have an original edge too without a bar
i would try an original floyd rose then a edge1
Old 08-12-2006, 10:16 PM
Dee  is offline
Edge bars can easily be found on e-Bay. Easy. No need to use anything else. I don't think an OFR bar will do the job at all.
Old 08-12-2006, 10:37 PM
RRAShred  is offline
Posts: 293  -  iTrader: (1)
the edge 2 bar will fit
Old 08-12-2006, 10:56 PM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
Theres no such thing as an "edge1", but, assuming you mean an edge... why try an OFR bar first?
Anyway, the OFR bar wont do the trick at all, unless you change the arm holder... Edge is push in / click, OFR has the screwy ring thingy on it to lock it in place...
Old 08-12-2006, 11:56 PM
Dee  is offline
Here you go: copy and paste this item number into e-Bay search box: 110020123522
If you miss that auction: 230017687703
The first one is cheaper.
arm holder, floyd rose, ibanez trem, ibanez tremolo, tremolo bar
FS: Ibanez lefty Trem arm for Edge - Lo Pro Ant1981 Classified Ads: Guitars and Gear 0 05-30-2006 09:07 AM
Custom Ibanez RG570/470 Edge trem w/refinish-You customize it! frankfalbo Classified Ads: Guitars and Gear 0 12-05-2005 12:43 AM
Question about the edge pro bridge on higher end Ibanez elpingua J-Custom, USA Custom & Prestige Ibanez Guitars 3 11-19-2005 10:20 AM
Ibanez S 7420 TRS to Edge trem and pickup recommendations tritheory Other 7-string Guitars 5 10-20-2005 02:53 PM
WTB: Ibanez Edge "HS" trem block and locking nut wemedge Classified Ads: Guitars and Gear 0 09-04-2005 01:17 AM
