Old 02-21-2008, 02:30 PM
Fizzy  is offline
Posts: 26  -  iTrader: (0)
Ibanez Gambale FGM400 switching question
The pull-push volume pot on the FGM400 switches in the neck pickup irrespective of the position of the 5-way pup selector.
I've had my FGM400 for a while now and never thought much about this, but I wondered what the default 'pushed-in' position should do with the neck pup. On mine it has the neck pup activated when in this position.
I have to pull the volume pot up to make the 5-way selector behave 'as normal' without the neck pup being switched in all the time.
Just wondered if this was correct, or whether the switching has been reversed on mine for some reason?
Old 02-21-2008, 02:43 PM
Crazy_Guitar  is offline
Posts: 1,319  -  iTrader: (0)
Reviews: 4
Re: Ibanez Gambale FGM400 switching question
I'm not familiar into FGM's wiring, but it "sounds" to me as if you have your push-pull inverted!
Old 02-21-2008, 04:34 PM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
I've no idea if that's right, but if your'e unhappy it's easy to change.
The pot will have a six pole switch body on the bottom, something like this:
You need to take any wires from the bottom pair of tags and transfer them to the top pair, keeping left to left, and right to right.
If there are any wires on the top tags you need to transfer them to the bottom, again keeping left to left and right to right.
Jim
Old 02-22-2008, 05:13 AM
Fizzy  is offline
Thanks guys, I'll have a look at the pot wiring.
Given that it sounds like the switching is reversed, are there any resources for a wiring diagram for the FGM400? I'd like to check out all the wiring in case there's any other mods in there.
Also if anyone here has an FGM400 I'd be interested to hear your thoughts on the switching and the guitar in general.
Old 03-08-2008, 06:42 PM
mike80sguy  is offline
Posts: 95  -  iTrader: (0)
I just picked one up today and it looks like I got the opposite youre having. When have the 5way sw in the bridge position I get a clear sound but when i pull up the volume button the sound drastically darkens.
Old 03-09-2008, 07:48 PM
Fizzy  is offline
Thanks for the info Mike - I'm intending to swap over the switching to return mine to 'normal'.
bridge position, neck pickup, neck pup, pole switch, wiring diagram
Question about the Ibanez JEM series shreddersymphony JEM and Universe Guitars 95 03-23-2008 02:55 PM
My new Ibanez Gambale FGM400 caprile Other Ibanez Guitars (including Premiums) 9 12-19-2007 05:08 PM
Ibanez Dayz 2007, 13 Summer Dates ibanezusa Local Jams & Events 2 10-04-2007 12:31 PM
Question about selling an Ibanez Shredlix Gear and Equipment 7 04-07-2007 06:05 PM
A/B test between Ibanez RG7421 and Schecter 007 Blackjack Mind Riot Other 7-string Guitars 23 12-06-2004 02:12 PM
