Ibanez RG320FM and Zakk Wylde Pickup set
Page 1 of 3
02-20-2006, 03:12 PM
Ravendark
Posts: 15 - iTrader: (
Hi guys,
I just bought and installed my new pickups today. The EMG-81 (bridge) and the EMG-85 (neck).
My guitar is the RG320FM with the Edge Pro II trem.
Well the first impression was lets say bad...
I did not notice any change in the sound of my guitar. I am not using an amplifier right now because I am at the university and the amp is home, but I have the Korg toneworks AX1500G processor.
I was expecting a heavier sound or at least something different.
But no!
Is there something wrong?
The old pickups were the stock powersound ones.
Thanks.
Ravendark
Find all posts by Ravendark
02-20-2006, 03:21 PM
ibanezcollector
Posts: 3,207 - iTrader: (
29
Re: Ibanez RG320FM and Zakk Wylde Pickup set
did you change the pots to 25k?
ibanezcollector
Visit ibanezcollector's homepage!
Find all posts by ibanezcollector
02-20-2006, 03:33 PM
Demiurge
Posts: 883 - iTrader: (
Maybe you connected the "quick-connect" cables the wrong way. The first time I installed an EMG I made that mistake and the pickup sounded weak as hell... then when I fixed it- OMG. If not that, and you used the pots included with the pickups, you either have some bad EMGs or some really good powersounds ;-)
Demiurge
Find all posts by Demiurge
02-20-2006, 03:43 PM
Ravendark
Well I have no idea.
The guy at the
guitar shop
installed the pickups.
What are the pots?
Thanks for your reply!
Edit: I will try to connect the quick-connect cables the other way around and get back to you
Ravendark
02-20-2006, 04:09 PM
lyconxero
Posts: 1,469 - iTrader: (
They are referring to the volume and tone potentiometers which control just that. For EMGs to work properly, you need to install the pots that come with the pickups. Also, even with EMGs I don't know how much you expect your tone to improve if you're just playing through an FX processor. You should hear a difference but you're not REALLY going to hear just how different they sound until you play through a REAL AMP.
lyconxero
Find all posts by lyconxero
02-20-2006, 04:18 PM
Ravendark
The guy at the guitar shop changed the volume and tone controls.
Now I am looking for a screwdriver to check if the "quick-connect" is connected the right way
Ravendark
02-20-2006, 04:47 PM
LonePhantom
Posts: 5,369 - iTrader: (
Reviews: 98
That's surprising that you haven't found much change in your sound. I hope it's just a bad install on your guitar and that it can be fixed up. Your guitar should have a huge sound now!
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
02-20-2006, 05:27 PM
Ravendark
Thats what I was expecting...
Ok, I connected the "quick-connect" cables the other way around but then I had no sound at all.
Is it possible that something went wrong? How can I find out?
Ravendark
02-20-2006, 05:30 PM
Ravendark
Also, (i dont know if this is relevant) the guy who installed th pickups, he originally installed the 85 at the bridge and the 81 at the neck and I told him to change them.
When I asked him to change them he told me that I wouldn't like it because the 85 is louder than the 81.
"Even
Zakk Wylde
uses the 85 at the bridge and the 81 at the neck" he said...
Ravendark
02-20-2006, 05:38 PM
Toto
Posts: 313 - iTrader: (
MISTAKE!
81 is 1.25Volts and 85 is 1.00V, 81 is a bridge PU but can be used in neck, BUT anyways guitar MUST have HUGE sound!
Toto
Visit Toto's homepage!
Find all posts by Toto
02-20-2006, 05:43 PM
Ravendark
Well I have the 81 at the bridge now and the 85 at the neck.
I dont know I got dissapointed because I also gave a lot of money...
Unless if its the FX's fault like lyconxero suggested.
But still, with the same settings shouldn't the guitar now sound better?
Even when I
palm mute
it, it sounds weaker than before...and the old pickups realy sucked!
Ravendark
02-20-2006, 06:23 PM
guitardevil2005
Posts: 442 - iTrader: (
what pups did u have before
guitardevil2005
Find all posts by guitardevil2005
02-20-2006, 06:35 PM
Ravendark
Powersound. The ones the guitar had when i bought it
Ravendark
02-20-2006, 07:07 PM
Algiman
Posts: 2,553 - iTrader: (
I strongly suspect that your processor is disguising the real sound. Do you use lots of compression? I find that EMGs need completely different compression settings to passives. Run the guitar through a real amp before judging it.
Algiman
Find all posts by Algiman
02-20-2006, 07:16 PM
Ravendark
I will try to find any guys with amps here at the accomodation and let you know.
I will also change the battery put a good one, duracell or something...
Thanks alot!
Ravendark
Page 1 of 3
death metal
distortion pedal
guitar shop
marshall amp
music store
palm mute
peavey bandit
power amp
practice amp
roland cube
tube amp
zakk wylde
RG2610 one pickup?
how to refinish zakk wylde les paul
ibanez zps dont flutter?
zakk wylde how tall
how big are zakk wylde's arms?
04:37 AM
