Well I picked up a purple S 470 thursday. The guitar is absolutely mint. It was being sold as used for $429.00. The funny thing is, like I said before, there isn't a mark on it. No fret wear, no fading of the cosmo black ZR trem or tuners, not a mark on the body. The only small thing were a few light scratches on the plastic trem cover on the back. The previous owner couldn't have played this guitar very often-if at all. Oh yeah, the guitar was set-up perfectly with GHS 9's. The intonation is dead on, and the action was set at about 1.30mm at the 12th fret with no buzzing encountered. Obviously who ever set-up this guitar knew their business.
So, this is my first experience with the ZR trem and an S series guitar. I've gotta' say this is the most comfortable guitar I've ever played. I love the RG's, but IMO, the contour of the S body feels like it was made to fit me. The neck is very nice, not to thin and not to wide. I can easily play this neck without my hand getting tired.
The pup's suck,'nuff said!
The ZR trem is unbelievable. It feels stiffer then the a lo pro or any similar trem, but I've always liked a stiffer feeling trem set up. The big plus is that although it feels stiffer, it is definitely smoother then the
edge trem on my 570. I've been beating the hell out of it, and it just won't go out of tune. The ZR looks to be well made with 1 or 2 small exceptions.
I'm not crazy about the way the bar is inserted into the trem, and the little plastic piece that it threads into doesn't give me a lot of confidence, but I'll have to wait and see what happens with regular use. The bar was always a little loose even when I tightened down the outside tension screw, but I put a piece of duct tape around the bar just above the threads and that solved the problem.
All things considered, out of a possible 5 stars I'd give this guitar a solid 4 stars for build quality and construction, 2 stars for tone, because the pup's are really bad, and a solid 5 stars for performance.
I hope this will help anyone that might be interested in buying this model. I would highly recommend it as a main guitar, once the pup's are replaced, or a solid back-up guitar in case your main one goes down.
Thanks for reading!
Danny
