Ibanez screws it’s S buyers over again..
Page 11 of 16
01-03-2007, 11:18 AM
Ke^in
Posts: 528 - iTrader: (
Re: Ibanez screws it’s S buyers over again..
I already did quote you but evidently I have to do it again!
Yes and neither times does it say
"there's nothing wrong with a 1 piece scarfed design."
I never said there was nothing wrong with it. NOT ONCE. I said the problems Ibanez had was with the junky wood. Had they used ALL TOP quality wood, I am sure there would be necks that screwed up now and then. But every company has that problem. That wasn't what was killing all the wizards.
Not that I didn't explain the difference between the two in my LAST post....
You did say that. I just quoted you, AGAIN.
R.I.F. That isn't what I said at all.
Ke^in
Find all posts by Ke^in
152
jemsite
Administrator
Posts: 9,271 - iTrader: (
Ke^in
Are you saying 1mm would make a difference either way? I sure hope not.
1mm can make a difference, all things equal, assuming the wood is a good cut.
arguing over Korean S guitars is very silly either way. Yuk
...glen
jemsite
Find all posts by jemsite
01-03-2007, 11:19 AM
Ke^in
jemsite
RIGH! ASSUMING the wood is a good cut. When the wood is not, 1mm wont help it.
...glen
Actually this is about the Prestige.
Ke^in
154
01-03-2007, 11:24 AM
jemsite
Administrator
^^ prestige can be korean too. meaningless designation to players with specific tastes in guitars.
which of those guitars on post 1 are MIJ? ...glen
jemsite
01-03-2007, 11:26 AM
Ke^in
jemsite
Correct, sorry. I was thinking you mean the lower end S guitars. I apologize
There are no "high end" ibanez S series made at this moment.
The fact that "it's only made in Korea" is what my complaint is part of. Well not where it's made but the stiplations that come with where it's being made.
Ke^in
156
01-03-2007, 11:27 AM
Posts: 19,352 - iTrader: (
You said there was nothing wrong with the design, it's a blanket statement! I quoted you directly, but of course you never said it.....
Who cares if it's badged Prestige, it's made by Cort and is in no way Prestige quality.
I don't care what your reply is, I'm not wasting any more time.
01-03-2007, 11:28 AM
S-man
Posts: 1,757 - iTrader: (
jemsite
...glen
There's one of the problems, Korean S, ever since they switched them to Korea you can't get a Wizard I.
They have turned it into a beginners guitar. That's what happens when you cater to the $500 guitar market and let the others (Prestige S) just fall in line. Perfect for hanging on the wall of Guitar Center.
S-man
Find all posts by S-man
158
01-03-2007, 11:29 AM
Ke^in
No, I said that wasn't the problem Ibanez had. BIG difference.
This is the third time now I have had to explain that to you.
See one is saying that said problem doesn't exist. The other is saying said problem exists, but that isn't the problem Ibanez was having.
Understand?
I agree. That is what my rant is about.
You obviously never cared before. Because you didn't pay attention to the last 2 I posted. That IS wasting your time. Not to mention this is about the 5th time you've said "I'm done" or something of the like.
Ke^in
159
01-03-2007, 11:30 AM
S-man
jemsite
None.
And that my friends, is how Ibanez screws it's S buyers again.
S-man
160
01-03-2007, 11:32 AM
Obviously the design was part of the problem, but no, it's not part of the problem Ibanez had?
01-03-2007, 11:33 AM
jemsite
Administrator
S-man
you'll never get an explaination from ibanez about what cort, etc. does. Wizard I was probably too unstable and IMHO should never have been created in the first place way back.
Next, there is no real market for pricy S guitars... they ARE beginner guitars if they're made by Cort.
Finally, when i and others tell you guys MIK is horrendous vs Prestige MIJ half the newbies think it's some country bias or cite a rare example of some good sounding MIK ibanez.
... glen
jemsite
01-03-2007, 11:36 AM
Ke^in
It could have very well been a small part. But the BIGGER problem, and the one that caused all the majority was the CRAP WOOD.
Had Ibanez used BETTER wood the scarf issues would be moot. Sure they would run into problem necks. Every company does.
ALL companies produce bad necks here and there. The REASON Ibanez had such BAD LUCK in the AMOUNT of necks that were crap with the wizard WAS BECAUSE OF THE CRAP WOOD. NOT because of the scarf.
Ke^in
163
S-man
jemsite
... glen
Do they put the Wizard I on the Prestige RG currently????
S-man
164
01-03-2007, 11:37 AM
S-man
I already know the answer...yes
Put that neck design/profile on the new S and make it in Japan.
I know they are beginner guitars ....that's why I said that
They didn't used to be.
S-man
165
01-03-2007, 11:38 AM
Ke^in
jemsite
Unstable with junky woods they were using.
Uh sure there is. Ibanez has been selling S prestiges for years by the buttloads.
Ke^in
Page 11 of 16
basswood guitar
basswood guitars
bridge pup
bubinga neck
electric guitar
equipped guitar
fat strat
fender strat
fender strats
frank gambale
fret guitar
fret guitars
fret neck
fret necks
fretboard radius
gambale model
guitar shop
humbucker guitar
ibanez dealer
ibanez guitars
ibanez neck
jem neck
jem neck profile
korean guitar
les paul
locking nut
locking stud
locking studs
maple fret
maple fretboard
maple neck
maple necks
neck finish
neck joint
neck thru
neil zaza
playing guitar
prestige guitar
prestige guitars
prestige wizard
pro edge
prs guitar
prs guitars
scarf joint
seymour duncan
shred machine
thicker necks
tung oil
warped neck
ibanez zps dont flutter?
compare ibanez grx40 squier telecaster affinity
are ibanez that are made in korea ok?
will an ibanez jem neck fit on an ibanez ex series body?
Leaving Ibanez guitars - No more jems for me
jem7pbk
12-11-2010
08:16 PM
'Custom' Ibanez
Shredder stuck in the 80s
05-16-2007
03:01 PM
Enquiring about 2nd guitars
GuitAust
10:40 AM
Did Ibanez cheap out with their stock pickups? [no, they're DiMarzio made for Ibanez]
TheJazzTerminator
224
08-18-2006
07:48 PM
Ibanez catalogs - call for scans
jemsite
82
03-27-2006
11:38 PM
04:29 AM
