Old 01-03-2007, 04:48 PM
Ayrton  is offline
Re: Ibanez screws it’s S buyers over again..
I actually read most of this(I know)and I have to say Kevin's definition of "dishonest" is a bit skewed.
Old 01-03-2007, 04:55 PM
Rich  is offline
Like I said, there were at least 20 quotes where he just flat out stated a "fact" that was nothing more than jibberish. One of them was calling me dishonest for stating just that!
Old 01-03-2007, 05:30 PM
S-man  is offline
Posts: 1,757  -  iTrader: (0)
I'll add this, It's not he same neck only 1mm thicker. The shape is WAY differant. Even Rich says the shape is too thick in the shoulders. Plus the radius is differant. The neck pocket isn't as deep as it used to be, which raises the pups and bridge higher than the Wizard I equipped guitars.
I personally wouldn't buy a new guitar that I have to shave the neck on (void warranty). The quality/consistancy has went down hill since they swithed to the Korean plant.
So, it's just one less quality guitar you can buy from Ibanez.
I think those are solid points and hard to argue with.
Though I'm sure someone will.
I just hate to see what used to be a good guitar turned into a beginners guitar. That's what has happened and it does seem like alot of people here have the, "if you don't like it don't buy it or buy something used" or "it's just a cheap guitar anyway attitude".
I know the S isn't a JEM, but come on guys, just show a little love for the cheapy S.
But you know, the passion to make a point is fading. I already have 3 S guitars and at this point, I'll be getting no more.
Of the people that have commented, I wonder how many have played an S with a Wizard I and an S with a Wizard II back to back. I know there are a couple/few, but I'm sure some haven't and are basing thier opinions off the differances between the RG Wizard I and RG Wizard II.
In the end it probably doesn't matter cause this thread has went to ....
Old 01-03-2007, 05:40 PM
Rich  is offline
I won't argue that MIK profile sucks eggs, and so does the finish they use on it, more gummy than slick. I'll be sure to relay it to Mak but I just don't see them doing a lot about it. Though you never know.
Old 01-03-2007, 05:44 PM
chlamy  is offline
Posts: 283  -  iTrader: (0)
I guess it only comes down to sales numbers of the S series, right ? As long as they are good, they will never ever do anything about it, the day the sales drop dramatically and beyond financially interesting, they would either discontinue it (?) or change something for the better. So how are the S series sales going Rich ?
Old 01-03-2007, 05:50 PM
Rich  is offline
I don't sell that crap
Old 01-03-2007, 05:51 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Honestly, that last point is the most interesting thing to come from this thread, the change in neck pocket depth by a full 8mm. That's pretty drastic; I'd be curious what the rational was, or if it just sort of fell through the cracks.
All this talk about neck thickness and screwing the customer sort of drove us away from what could have otherwise been an interesting discussion - I haven't played a recent wizard II, but the last I played (on an older S470) I actually rather preferred to the Wizard - it was a bit strattier, but in a good way. Has the shape itself changed?
Old 01-03-2007, 07:15 PM
S-man  is offline
Nevermind.
Old 01-03-2007, 09:46 PM
Drow Swordsman  is offline
Posts: 741  -  iTrader: (2)
There are NO Wizard necks on J Customs, not 17-19mm Wizards you're all thinking about.
The current Wizard is 18-20mm and 2mm wider than pre 05' Wizards
This kind of confused me.
I'm guessing at this point what you mean is that though the J Customs are 17-19mm...they aren't the same shape as the original Wizard. Is that correct?
If not, just pointing out that according to the Ibanez Japan site..
http://www.ibanez.co.jp/japan/produc...G8470F_PR.html
When you click neck dimension it does say 17mm at first and 19mm at 12th.
The Ibanez site could be wrong, that's probably not the first time that's happened.
Or it could be my first guess and that you mean that while it is 17-19, it's not the Wizard I shape.
Old 01-03-2007, 09:48 PM
Rich  is offline
The specs are wrong, I have 3 of them here and they're all 18-20
Old 01-03-2007, 09:57 PM
Oh I see.
Thanks for clearing that up then.
Old 01-03-2007, 10:55 PM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
I knew this would end in tears
Old 01-04-2007, 12:05 AM
Ayrton  is offline
So was the real reason the original (thinnest) neck got changed due to them just being too thin and prone to cracking or was there another reason?
Old 01-04-2007, 12:15 AM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
me too
Old 01-04-2007, 01:52 AM
ScottB  is offline
Posts: 2,208  -  iTrader: (12)
Images: 8
Post #1 had ticking time bomb written all over it. I seriously doubted this thread would last more than 4 pages.
Leaving Ibanez guitars - No more jems for me jem7pbk JEM and Universe Guitars 141 12-11-2010 08:16 PM
'Custom' Ibanez Shredder stuck in the 80s JEM and Universe Guitars 40 05-16-2007 03:01 PM
Enquiring about 2nd guitars GuitAust Vendors, Auction & Reseller Talk 27 09-24-2006 10:40 AM
Did Ibanez cheap out with their stock pickups? [no, they're DiMarzio made for Ibanez] TheJazzTerminator J-Custom, USA Custom & Prestige Ibanez Guitars 224 08-18-2006 07:48 PM
Ibanez catalogs - call for scans jemsite Other Ibanez Guitars (including Premiums) 82 03-27-2006 11:38 PM
