Old 01-01-2007, 04:42 PM
Rich  is offline
Re: Ibanez screws it’s S buyers over again..
They're WIDER by 2mm, thicker by 1.
Old 01-01-2007, 06:12 PM
Ke^in  is offline
Posts: 528  -  iTrader: (0)
Originally Posted by vmx23 View Post
OMG, are you just dense? 2003 MIJ Wizard II necks can only be found on the 2003 MIJ RG4xx series, the only series in 2003 where MIJ Wizard II necks were used. Where else can you find a 2003 MIJ Wizard II neck? Point is, you never play a 2003 MIJ Wizard II neck before, which is very similiar to a 2005 Prestige Wizard.
Point is, it has nothing to do with the thread. Not a thing. Not only are you being arguementive about something that is off topic, you are also being pretentiously condescending too.
Anyway, Rich has said it. The new Prestige are THICKER. Wizards II in papers are 2mm thicker than the old wizards. I guess, I am not crazy for saying a 2005 Prestige Wizard are very similiar with an 2003 MIJ Wizard II neck with the Ibanez neck profile tolerence of +- 1mm.
I never said they weren't thicker. Pay attention. I said they didn't feel like WizardIIs.
They aren't SHAPED the same. I am not TALKING ABOUT THICKNESS.
Now they may feel like some obscure WizardII that was MIJ in 2003, but ....
NON OF THIS HAS ANYTHING TO DO WITH THE TOPIC NOR IS IT RELEVANT
Old 01-01-2007, 06:16 PM
Ke^in  is offline
Originally Posted by Rich View Post
There are NO Wizard necks on J Customs, not 17-19mm Wizards you're all thinking about.
The current Wizard is 18-20mm and 2mm wider than pre 05' Wizards.
Well then Ibanez is being deceiving by CALLING them wizards. Which is just another complaint I have. False advertising.
If you're talking about the lousey profile of the MIK W2's then I fully understand, they suck. Far too hard D shaped with way too much meat in the shoulders. For whatever reason, that's the way they are. If you don't like it, then buy USED MIJ!!
I did. I'd also like to buy some new Ibanez guitars sometimes. This don't look like it's going to happen. So Ibanez now has 2 different versions of the WII as well?
Sounds like a cluster-fck How is the consumer supposed to know all this?
Nobody is pinching pennies or screwing anybody.
It costs less to make guitars in Korea, yet the Prestige costs the same.
They production costs aren't the same. While they may be getting less so as years go on, in 2005 the S costs less to make. But Ibanez sold it for the same price.
A sizeable amount of production capacity HAD to be moved to Korea as Fujigen clamps down on available capacity. The S was a victim, as was any S derivative, and if you REALLY knew how much of the MIJ production work is actually being done in Korea and shipped back and forth this would be a completely different thread.
I am not complaining about where it was being made. I said Ibanez should start making wizard profile necks in Korea as well. What is stopping them from doing that?
But you just admitted to what I was saying in the thread. The S is a victim. And so are those that buy it. It's not the S that it once was.
Old 01-01-2007, 07:20 PM
Rich  is offline
Ibanez can call or rename or reprofile any neck they want and call it whatever they want. They are the manufacturer.
And not only is Korea getting very expensive, but WHAT THE MARKET WILL BEAR is the biggest factor in pricing. Don't like it, don't buy, it's THAT SIMPLE.
Old 01-01-2007, 07:25 PM
Ke^in  is offline
Yes they can! But that doesn't make it honest.
Right, but that shouldn't stop someone from attempting to get Ibanez to fix things.
The S simply isn't the guitar it used to be. If enough people complain they will attempt to do SOMETHING about it. What that would consist of, I have no clue.
But Ibanez does have a history of attempting to cater to large complaints one way or another.
The wizard simply belongs on the S.
Otherwise It would like putting a wizard on a LesPaul. Simply doesn't belong.
Old 01-01-2007, 07:29 PM
Rich  is offline
My 78' Les Paul has a 19-21mm neck
Honest is whatever Ibanez says it is, they give the specs for it. It has CHANGED, get used to it. Maybe you should go chase some UFO's.
Old 01-01-2007, 07:32 PM
Ke^in  is offline
What does UFOs have to do with anything. I am not arguing that it is whatever Ibanez says it is.
I don't know what they fuss is about wanting Ibanez to start making quality S series guitars again.
I mean if they started screwing up Jems I am sure the backlash would be justified?
Old 01-01-2007, 07:34 PM
Rich  is offline
No, you're just arguing it's dishonest and deceiving in some way for them to make changes, puhlease.
Old 01-01-2007, 07:35 PM
Ke^in  is offline
Oh I still believe that them calling a neck a "wizard neck" and it not having a wizard profile IS dishonest. Why would they call it that other than to deceive?
Old 01-01-2007, 07:39 PM
Rich  is offline
I'm not repeating things 2 or 3 times because you don't buy them the first time. Again, go chase UFO's.
Old 01-01-2007, 07:42 PM
Ke^in  is offline
Just because I don't agree with what you say doesn't mean you have to repeat yourself.
Again my beliefs have nothing to do with UFOs.
Old 01-01-2007, 07:45 PM
Rich  is offline
>>You've given me no other reason Ibanez would do this.
Reason for what, to make a CHANGE?! Puhlease, I've already given you the reason for the change. And they're the manufacturer, they can change it to whatever they want, call it whatever they want, and then have some people like you make up huge conspiracy theories out of how they're just out to dupe buyers
Old 01-01-2007, 07:47 PM
Ke^in  is offline
No I mean make a change and then STILL call it the same thing. Not just make the change.
Why did they call the wizard II wizard II?
Why didn't they just call it "wizard" as well?
Old 01-01-2007, 07:49 PM
Rich  is offline
I'm not beating my head on this wall any longer.
Old 01-01-2007, 07:55 PM
Drow Swordsman  is offline
Posts: 741  -  iTrader: (2)
I just have a question...
It seems that from what I've read on here that Ibanez makes guitars at Fujigen with several other guitar manufacturers by sharing the factory in a way. Is that correct?
Now if Ibanez bought their own factory, could all the prestige guitars be made in Japan without a problem? It'd be their factory so the production capacity would be 100% Ibanez so they could make more models in Japan.
Is this not possible? Ibanez is a pretty large guitar manufacturing company, I'm hoping over time they could pay something like their own factory off without increasing the prices of their guitars...
But I'm just asking a question not making any facts. If someone could help me understand why this move hasn't been made than I'd be grateful.
And I have one more question...
You said "if we knew how much of MIJ production is actually being done in Korea"...
I'm almost afraid of the answer...but could you tell us how much of the MIJ work is really being done in Korea??
Leaving Ibanez guitars - No more jems for me jem7pbk JEM and Universe Guitars 141 12-11-2010 08:16 PM
'Custom' Ibanez Shredder stuck in the 80s JEM and Universe Guitars 40 05-16-2007 03:01 PM
Enquiring about 2nd guitars GuitAust Vendors, Auction & Reseller Talk 27 09-24-2006 10:40 AM
Did Ibanez cheap out with their stock pickups? [no, they're DiMarzio made for Ibanez] TheJazzTerminator J-Custom, USA Custom & Prestige Ibanez Guitars 224 08-18-2006 07:48 PM
Ibanez catalogs - call for scans jemsite Other Ibanez Guitars (including Premiums) 82 03-27-2006 11:38 PM
