Ibanez screws it’s S buyers over again..
Page 9 of 16
01-02-2007, 08:20 PM
Ke^in
Posts: 528 - iTrader: (
Re: Ibanez screws it’s S buyers over again..
-Rhaab
wizard I is thicker than II?
Wah? No.. other way around.
Ke^in
Find all posts by Ke^in
122
01-03-2007, 01:46 AM
crevis
Posts: 2,599 - iTrader: (
S-man
It's also not about 1pc. vs. 3pc. vs. 5pc. or any kind of crazy talk about glue joints slipping or whatever that one guy was trying to say. I personally think he was all over the map and agrueing just for the sake of agrueing.
That was a discussion about why ibanez changed the neck in the first place.
I would rather pay a little extra to make a compromise so they could still make necks with wizard specs, its not really fair that they give you an awesome neck and then just take it away completely, they could have just made a couple of more expensive models with a better neck.
and the neck poket depth is a korean thing, all the MIKs ive owned have that, from RGs to Ss to anything made in that factory.
crevis
Find all posts by crevis
123
01-03-2007, 02:03 AM
Ke^in
crevis
The discussion was as to why the S stopped getting the wizard. And it had nothing to do with faulty original wizards.
Ke^in
124
01-03-2007, 02:46 AM
crevis
Ke^in
It stopped getting the wizard because of the faulty necks and the koreans are incapable of making a wizard I that wouldnt have the same problems. If it was still japanese, it would still have the wizard I, thats always been the case and the're not going to change it just because the S is MIK now.
crevis
125
01-03-2007, 02:54 AM
crevis
The thickness of the wizard II is a fale safe, the radius/curvature/neck pocket etc is just a lack of care and knowledge like with all MIKs.
crevis
126
01-03-2007, 04:34 AM
Dee
Posts: 8,514 - iTrader: (
crevis
If that's so, how come the (Japanese) RG
Prestige guitars
don't have the original Wizard?
Dee
Find all posts by Dee
127
01-03-2007, 08:00 AM
Ke^in
crevis
No it had nothing to do with early wizard necks being faulty. Nothing. But if you feel it does, feel free to back up your accusations.
No, not can't. But wont because it would cost too much.
You just contradicted yourself. You claim it doesn't have it because wizard necks were faulty, then you claim if it was still made in Japan it would still have the Wizard I. Which is exactly what I said. And who says Ibanez wont change it? They change stuff all the time.
At one time I was told Prestiges would never be made in Korea as well.
Ke^in
128
01-03-2007, 08:01 AM
Ke^in
Dee
If that's so, how come the (Japanese) RG Prestige guitars don't have the original Wizard?
1mm thicker wont make a difference either way in stability. I have no idea why Ibanez screwed up the RG wizard in 2005. Other than it might be CHEAPER to do so. Because that is what Ibanez is all about now. Cutting corners.
Ke^in
129
01-03-2007, 08:43 AM
no1spretty
Posts: 362 - iTrader: (
Reviews: 4
Im too lazy to read through all this thread but ikebe-gakki has a maple-boarded S540. I dont know if this has been mentioned
no1spretty
Find all posts by no1spretty
130
01-03-2007, 09:20 AM
Posts: 19,352 - iTrader: (
Ke^in
Ke^in
How about you take your own advice and start backing up your own [false] accusations.
01-03-2007, 09:53 AM
Ke^in
My accusation is that Ibanez doesn't put the wizard on the S because the are all made in Korea now. And Korea doesn't make wizard necks. Actually that isn't a accusation. That is why they don't come with them. And that isn't false.
As far as the accusations of them being penny pinchers, they are. The Edge Pro doesn't come with
locking studs
because of this. The reason the wizard EVEN HAD PROBLEMS to begin with was because of low grade maple used on some of the earlier cheaper
Ibanez guitars
. That really isn't a false accusation either. Because I have instances to back them up.
As far a 1mm making a HUGE difference in stability, I hope you aren't attempting to say it does...
Ke^in
132
01-03-2007, 09:55 AM
Ummm, yea........
01-03-2007, 09:56 AM
Ke^in
no1spretty
Nice. Not big on maple fretboards though.
Ke^in
134
01-03-2007, 09:59 AM
Ke^in
Ummm, yea........
Are you saying 1mm would make a difference either way? I sure hope not.
toshiro
Be that as it may, I've seen enough warped necks to know there are factors outside thickness involved.
Is a multi-piece neck going to be less prone? Of course, glue is stronger than wood. Are both capable of warping? Yes. Is that one mm going to stop the neck from warping where a 17mm would? Not IMO from seeing 20+mm necks warped to hell.
Ke^in
135
01-03-2007, 10:02 AM
I sure hope you don't believe everything you read, and then post like YOU know the facts based on it
ABSOLUTELY it makes for a more stable neck. Will it keep a neck made of bad wood from going bad? NO. Will it help keep a good neck good, YES!!
Page 9 of 16
basswood guitar
basswood guitars
bridge pup
bubinga neck
electric guitar
equipped guitar
fat strat
fender strat
fender strats
frank gambale
fret guitar
fret guitars
fret neck
fret necks
fretboard radius
gambale model
guitar shop
humbucker guitar
ibanez dealer
ibanez guitars
ibanez neck
jem neck
jem neck profile
korean guitar
les paul
locking nut
locking stud
locking studs
maple fret
maple fretboard
maple neck
maple necks
neck finish
neck joint
neck thru
neil zaza
playing guitar
prestige guitar
prestige guitars
prestige wizard
pro edge
prs guitar
prs guitars
scarf joint
seymour duncan
shred machine
thicker necks
tung oil
warped neck
ibanez zps dont flutter?
compare ibanez grx40 squier telecaster affinity
are ibanez that are made in korea ok?
will an ibanez jem neck fit on an ibanez ex series body?
Leaving Ibanez guitars - No more jems for me
jem7pbk
12-11-2010
08:16 PM
'Custom' Ibanez
Shredder stuck in the 80s
05-16-2007
03:01 PM
Enquiring about 2nd guitars
GuitAust
10:40 AM
Did Ibanez cheap out with their stock pickups? [no, they're DiMarzio made for Ibanez]
TheJazzTerminator
224
08-18-2006
07:48 PM
Ibanez catalogs - call for scans
jemsite
82
03-27-2006
11:38 PM
03:39 AM
