Old 04-01-2009, 08:02 PM
laihojrxo  is offline
Posts: 15  -  iTrader: (1)
ibanez xiphos neck dive problem?
what the title said. how did you solved one on yours? (or how would you fix it).
the neck dive is really annoying, esp when you're in a band and gig a lot...
other than that, so far i love my new xiphos.
Old 04-01-2009, 10:26 PM
AnDr3wYoN  is offline
Posts: 117  -  iTrader: (0)
Re: ibanez xiphos neck dive problem?
Well on my previous S, it had the neck dive problem as well. I stacked coins and taped them together then fit them into the control cavity. They're heavier than you expect them to be. Around 15 quarters in the back of my S's tiny control cavity was able to balance it out properly.
If that doesn't help, then you could try drilling a new front strap lock
Old 04-15-2009, 12:41 PM
Twebbz  is offline
Posts: 31  -  iTrader: (0)
It's been said that you have to relocate the rear strap button above and close to the output jack (not on the back). Ibanez did the fix for 2009 as the picture shows. I've got a new 2008 Blue Chameleon arriving this Friday and I'm gonna hate to do it.
Old 04-20-2009, 10:26 AM
Twebbz  is offline
I received my new XPT700BCM and before I repositoned the rear strap button as pictured above, I simulated it by placing the cord through the strap hole then plugging the cord into the guitar. Holds pretty well just for a quick try out. WELL, THE NECK STILL DIVES but not as severely as with the button at the top point. SO, it seems that the rear strap button needs to be positioned further down at the first flat surface coming up from the center curve, in line with the 6th string.
Check out this video on YouTube.
http://www.youtube.com/watch?v=kF4gf1gWR6U
EDIT: I repositioned the rear strap button inline with the 6th string and it still dives though not as much. Seems like you need to reposition the forward button from the back to up under the horn as some guys have done. Trouble is that the neck gets in the way of a drill and a screwdriver. Hmmmmmm.....
Old 05-02-2009, 07:14 PM
Twebbz  is offline
Well, I just put some masking tape up under the horn and screwed in the strap button with a screwdriver. The neck did not get in the way. This is how it sits using a slippery nylon strap.
Old 05-02-2009, 09:34 PM
toshiro  is offline
Posts: 1,812  -  iTrader: (11)
I have a 2009 Xiphos, and only moved the upper strap button:
Though, I usually prop the "V" part up with my right leg for more stability/control.
Old 05-02-2009, 11:09 PM
Twebbz  is offline
If you can keep the front strap going over the horn in the direction of the headstock like Toshiro shows, it pops the neck up further. Mine tends to slip back so I fastened an inch wide velcro strap around the guitar strap and most forward edge of the horn point. Seems to keep it in place pretty well. Still, It's OK just letting slip back the way it wants to without the velcro strap.
Old 05-04-2009, 08:32 AM
GTR-MAN  is offline
Posts: 1,056  -  iTrader: (0)
Images: 8
Those white Xiphos look awesome !!!!
Old 05-04-2009, 11:22 AM
toshiro  is offline
That they do, especially when you swap all the hardware for black(and some other things):
Old 11-08-2009, 06:36 PM
DFWzach  is offline
Posts: 6  -  iTrader: (0)
Question
How can I get my hands on one of them new fangled 2009 models? haha
Old 11-08-2009, 08:14 PM
Yousef  is offline
Posts: 378  -  iTrader: (2)
Nice Iced Earth shirt dewd. \m/
Old 11-09-2009, 06:13 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
try moving the rear button toward and closer the front button, in the back of the body. it definitely solves the problem. of course that would work better with a DiMarzio Cliplock strap, as it doesn't have buttons poking your belly.
Old 11-10-2009, 05:52 PM
alex_vai7V  is offline
Posts: 2  -  iTrader: (0)
is toshiro's setup pretty easy to do?
And kind of unrelated but how's the playability of the neck on the xiphos? I'm considering getting one if the neck dive is less of an issue but am curious as to the overall feel of the guitar, I have an rg2550 and was wondering if the necks feel substantially different beside the fact that one is obviously a prestige...
Old 11-10-2009, 06:18 PM
Agent540  is offline
Posts: 1,073  -  iTrader: (0)
Elegant ! congrats !
Old 11-12-2009, 04:19 PM
The Rossness  is offline
Posts: 44  -  iTrader: (1)
Reviews: 13
I just rest my forearm on the upper wing- problem solved. +, neck dive isn't that bad.
Ibanez xiphos sirshredsalot Other Ibanez Guitars (including Premiums) 8 11-04-2008 08:08 AM
Nearly New Ibanez Xiphos F/S UK £400 Trev Classified Ads: Guitars and Gear 1 09-04-2008 07:05 AM
Set-neck problem on old Ibanez Studio no1spretty Tech: Setup, Repairs and Mods 0 04-22-2006 11:49 AM
Neck problem with ibanez 1570 (picture inside) yannvii Other Ibanez Guitars (including Premiums) 6 12-08-2004 12:29 AM
