Old 11-12-2006, 06:31 AM
canneerr  is offline
Posts: 24  -  iTrader: (0)
i'm about to setup my new backup guitar,need help
i bougt an exr170 2 days ago,i'll use it as a backup guitar...There was 2 problems while setting it up..
1-)The low E and maybe A strings are buzzing if i pick a little hard,i checked the action and it's normal as the manual says.I don't know why it is buzzing,i thought the new strings can buzz a little but i'm not sure about this ..
2-)The single pickup is high for me,i tried to lover it but it lowers with an angle,when i lower it,the bridge side of the pickup lowers very much and the neck side lowers less than the other side(hovever it's a single pickup).How can i lower the pickup and make it paralell to the body?
Old 11-12-2006, 09:14 AM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
Re: i'm about to setup my new backup guitar,need help
Number 1 seems like it needs a truss rod adjustment.
Regards
André
Old 11-12-2006, 10:47 AM
NeglectedField  is offline
Posts: 945  -  iTrader: (0)
Direct mount single pickup height adjustment is a total pain. If it has some kind of foam underneath it might be that, so it might be a good idea to remove the strings, unscrew it and see.
EXR/EDRs come very poorly set up, I remember I was trying an amp once and I asked to use the EDR170, but something was totally messed up with the trem so I ended up using a Schecter instead.
pickup height, rod adjustment, truss rod, truss rod adjustment
UV7BK setup Demogorgos Tech: Setup, Repairs and Mods 1 04-26-2006 07:51 PM
eventide H3000 series setup help eaton Gear and Equipment 1 07-10-2003 11:38 PM
Setup problems with my DBK...good price for a quality setup? Guitarlos2 Tech: Setup, Repairs and Mods 7 07-10-2003 03:39 PM
How to setup ur guitar like Joes? bbovee JS (Satriani Model) Ibanez Guitars 12 06-04-2002 02:29 PM
Changing string gauges - What's to be setup again ? Wicked Blade Tech: Setup, Repairs and Mods 2 04-22-2001 02:21 PM
