Old 07-31-2006, 02:55 AM
rub_800  is offline
Posts: 93  -  iTrader: (0)
Question
Improve edge III
hello friends I was wondering if some of you could give some advice to improve the performance of the edge III bridge... I would swap it for a OFR but it's dificult to find bridges here in Mexico.. so until I can get one... what can I do to improve tunning stability?
Damn!! I would had bougth a 1550...
Sorry for mi english..
Old 07-31-2006, 02:57 AM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
Re: Improve edge III
I think no other option but to change the trem, anyway I used edge 3 trem all the the time at the store and they work great! I think you need to really set it up perfectly for it to function perfectly
Old 07-31-2006, 02:59 AM
j.arledge  is offline
Posts: 1,803  -  iTrader: (30)
the edge 3 wont swap out directly with an original floyd or at least i dont think it will . i am sure someone will know for sure .
Old 07-31-2006, 03:09 AM
rub_800  is offline
Ok.. so anyone could give some advice to set it up? Because a think there's no much things to set apart from the spring's claw..
Old 07-31-2006, 03:14 AM
mi2tom  is offline
Just like any other trem you need to stretch the string first before locking it
Old 07-31-2006, 03:25 AM
rub_800  is offline
I was wondering too.. old strings could affect stability?
I do it anytime I change the strings buddy what more can I do?
Old 07-31-2006, 03:40 AM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
How about fitting a Tremol-no? Should improve stability and give a more accurate return to pitch, I think.
nuno  is offline
Posts: 4,725  -  iTrader: (0)
YES, definitely.
click on the Ibanez Rules banner above, then go to the Tech section. no need for anything else.
Old 07-31-2006, 04:03 AM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
The tremolno is a blocking mechanism, either blocking tremolo function altogether or only allowing pitched to be lowered. It does give a more accurate return to pitch, but you cant use the bar to raise pitch in this state.
Old 07-31-2006, 12:21 PM
rub_800  is offline
[quoute="sniperfrommars1"] but you cant use the bar to raise pitch in this state.
[/quoute]
and it's difficult to find one of those in mexico... :s
Old 07-31-2006, 12:54 PM
markg5150  is offline
Posts: 2,361  -  iTrader: (2)
Definitely check ibanezrules.com but also
1. Stretch strings in properly
2. Adjust springs so that the angle of the trem is parallel to the body
3. Lock the nut, but not too tight
Old 07-31-2006, 07:26 PM
Put a bit of chapstick on the knife edges. I would imagine they sell that in mexico. Rich shows you how to do that at www.ibanezrules.com Pretty much you need to completely go over that website with a fine toothed comb, on top of t hat he has some of the best guitar porn ive ever seen.
edge iii bridge, locking tremolo
Edge III swap for another Edge model trem? lespaulreedsmith Other Ibanez Guitars (including Premiums) 36 03-14-2009 06:10 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
lo pro edge vs edge pro 7 cakewalkr7 Tech: Setup, Repairs and Mods 4 02-11-2005 12:23 AM
