Old 01-22-2009, 01:39 PM
maverick52  is offline
Posts: 2  -  iTrader: (0)
Lo-TRS II replacement for s470???
I recently obtained an older s470 qs that came with a lo-trs II trem. I've heard numerous people explaining how horrendous the lo-trs II was so I'm considering an upgrade. I really like the edge bridges but I've heard that aside from routing (which I wouldn't mind doing) that the post spacing is different. lo-trs has 74 mm while edge pro's have 73mm?
does a half millimeter on each side make that much of a difference? since one of the knife edges is totally straight and not rounded might it still fit barely?
Old 01-22-2009, 01:52 PM
moebius  is offline
Posts: 2,042  -  iTrader: (0)
Re: Lo-TRS II replacement for s470???
No offense intended, but if you do a search you may find a lot of threads on replacing lo-trs II trems. This has been discussed many times before.
Good luck.
Old 01-22-2009, 05:20 PM
LonePhantom  is offline
Posts: 5,368  -  iTrader: (6)
Reviews: 98
Gotoh licensed Floyd Rose - go get it! Locking studs too so take the time to replace the LO-TRS II studs and anchors.
Old 01-25-2009, 06:22 PM
schmintan  is offline
Posts: 35  -  iTrader: (0)
I got a schaller floyd rose from Stewmac. solid brass block really really really improves the sound of the guitar and it holds tuning like nothing else i know! plus it just drops into the cavity of the Low TRS II, so no mods needed which is good if your a menace with electric tools.
edge, lo trs, lo trs ii, s470, tremolo
Got the S470! UsrName Other Ibanez Guitars (including Premiums) 15 05-11-2007 06:14 PM
Old S470... Matt08642 Other Ibanez Guitars (including Premiums) 5 10-24-2006 11:31 AM
Replacement for Lo TRS Trem 2 on S470 Leader Tech: Setup, Repairs and Mods 3 01-26-2006 11:19 PM
replacement neck for s470? superpato Other Ibanez Guitars (including Premiums) 3 08-03-2004 12:02 AM
Suggestions for replacement PUP's for S470 JLM777 Pickups & wiring 12 03-04-2003 12:17 AM
