Old 05-08-2005, 08:03 AM
maxfax  is offline
Posts: 1  -  iTrader: (0)
Lo TRS to Edge Pro conversion
H i guys. I recently bought an ibanez js 100 body and neck from ****. I have done it up with all the hardware from the js 1000 but I am being thwarted by the trem. I picked up a trs for like $20 to tie me over, but i really want to replace that flappy ass chunk of crap. I have an old edge knocking around but it doesnt fit without routing. I know an edge pro 2 will fit, but i want to know if an edge pro will fit. I dont mind doing routing inside the cavity to make the trem fit, but i dont want to rout the surface of the guitar because i sprayed the guitar, and i dont want to have to do it again.
Thanks a lot
Old 05-09-2005, 12:53 AM
toshiro  is offline
Posts: 1,812  -  iTrader: (11)
Re: Lo TRS to Edge Pro conversion
The Edge Pro won't intonate in a body routed for a TRS(or any rout other than the one for it). YOu'd be better off with an Original Floyd if you don't want to modify the body for an Original Edge.
Old 05-09-2005, 02:51 AM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
Thanks a lot
You are sure that an Edge Pro II will fit? If so then that is good to know. Install an OFR or do the routing for the Edge.
Regards
André
Edge III swap for another Edge model trem? lespaulreedsmith Other Ibanez Guitars (including Premiums) 36 03-14-2009 06:10 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
Lo-Pro Edge Conversion ultra zone Tech: Setup, Repairs and Mods 21 09-19-2002 09:19 PM
