Old 02-21-2006, 01:14 PM
bradc1988  is offline
Posts: 11  -  iTrader: (0)
Locking nut problem
Ok I have an Ibanez RG320FM with an Edge Pro III system and I'm having a problem screwing a screw into the nut. The pad for the E and A string can't be held tight because the threading in the hole is stuffed so the screw won't screw into the hole properly. Ok, if you've managed to keep up....What are my options? The only one I can come to is I need a new nut, but that's going to cost something that I don't have right now and I don't want to end up getting the wrong one or something if I ship it from America.
So, any help?!?!
Thanks in advanced.
EDIT: Probably shouldv'e made this in the Toolbox....
Old 02-22-2006, 12:46 PM
Champagne Mist  is offline
Posts: 153  -  iTrader: (0)
Re: Locking nut problem
sounds like you've busted your nut....
Old 02-22-2006, 01:24 PM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
That's ususally a good thing
Old 02-22-2006, 01:34 PM
thebigugly  is offline
Posts: 147  -  iTrader: (0)
Check out Rich at Ibanez Rules for that part or your local store. You can retrofit an R3 or R4 flyd nut but i am not sure if it is a direct fit with the top lok. But yeah sounds like new nut time.
Old 02-22-2006, 01:51 PM
Rich  is offline
Posts: 19,348  -  iTrader: (21)
It can be helicoiled, or replaced. I have the nuts in stock, or you can find somebody local that has a M4 helicoil kit.
Old 02-23-2006, 01:42 AM
superhairycamel  is offline
Posts: 338  -  iTrader: (0)
it might just be the slightly wrong allen key size. is it the one you got with the guitar?
i had a smilar problem with my s470 but it turned out just to be a very slightly too thin allen key.
Old 05-30-2006, 01:16 PM
Sorry for the very, very late reply, I totally forgot about this and have been busy with Uni, and my nut is still fooked.
It's the one that came with the guitar, and I've tried screwing it in without the pad and it just drops into the hole a few mil which means it can't get enough grip with the pad to screw in.
Funnily enough I made a tap a few weeks ago as a prac in my course, but won't that make the hole bigger? Oh and I would buy them off you but $60 US is way to much to spend on a nut.
There are some going on **** for like $10-20 that are bottom mounting and 43mm, but I'm not sure if they'd fit. And what's R3 and R4?
Thanks for the help guys.
Something like http://cgi.****.com.au/BLACK-FLOYD-R...QQcmdZViewItem
or
http://cgi.****.com.au/Mighty-Mite-4...QQcmdZViewItem
edge pro iii
rg 1527 locking nut problem shreddies Other 7-string Guitars 3 08-04-2005 08:10 PM
Sperzel Locking Tuner Problem stratoskier Tech: Setup, Repairs and Mods 8 05-05-2005 12:34 AM
Lo Pro Nut Problem! - The locking pads don't fit! 7 Dying Trees Tech: Setup, Repairs and Mods 10 11-18-2001 04:55 PM
locking nut tuning problem - string retaining bar all the wa utopia Archived Topics and Common Questions - GO HERE FIRST 14 10-15-2001 10:55 AM
locking nut tuning problem - string retaining bar all the wa utopia Tech: Setup, Repairs and Mods 12 02-16-2001 02:07 AM
