Old 01-19-2008, 03:01 PM
just42dave  is offline
Posts: 373  -  iTrader: (6)
neck bolts and ferrules for rg550
hi i just bought the neck bolts fro a rg321 i have the right ferrules for the rg550 they are thinner will these bolts work the same
Old 01-21-2008, 09:49 AM
Re: neck bolts and ferrules for rg550
gosh youd think someone would no the answer to this....ill try the ibanez forum
Old 01-21-2008, 10:55 AM
brianxtr  is offline
Posts: 1,642  -  iTrader: (8)
sure someone knows it here!how old is the rg550?and there is a difference between the japan and korea guitars..
Old 01-21-2008, 09:30 PM
LonePhantom  is offline
Posts: 5,369  -  iTrader: (6)
Reviews: 98
Are you saying the ferrules are thinner, but the hole for the screw is the same? It should be fine, just try it, you can't damage anything by trying it if the screws are the correct diameter.
Old 01-22-2008, 10:19 AM
Talking
thanx phantom yeah the korean ferrules are a bit thicker than the japan
Old 01-22-2008, 10:26 AM
2001 superwizard going to a93ltd body
Old 01-22-2008, 05:15 PM
Reviews: 98
They will be fine, they are not going to do anything wrong or break anything just because they are thicker or thinner!
neck bolts
