Neck specs
06-05-2008, 09:34 PM
bLYNDcYDE
Posts: 24 - iTrader: (
Neck specs
Would anyone happen to know the technical info on a rg-320 neck?
Heel width?
Nut width?
Neck radius
Locking nut size?
bLYNDcYDE
Find all posts by bLYNDcYDE
06-06-2008, 12:04 AM
LonePhantom
Posts: 5,366 - iTrader: (
Reviews: 98
Re: Neck specs
Funnily enough this information can be found on the Ibanez site!
Scale 648mm/25.5"
a : Width at Nut 43mm
b : Width at Last Fret 56mm (at 21 F)
c: Thickness at 1st 19mm
d : Thickness at 12th 21mm
Radius 400mmR
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
neck radius
parker are they neck thru
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
how measure guitar specs
Damaged Neck Screw Holes On My Body
Eddie_V_H
Tech: Setup, Repairs and Mods
04:03 AM
Wizard Neck Specs?
wixomwhat
12:48 AM
Painted neck? Sanded neck?
Drache713
Other 7-string Guitars
12:45 AM
JEM neck specs in inches
Erico
06:32 PM
Changing Vine inlay colors - things that make you go hmmmmmm
tomizm
34
04-13-2001
03:14 PM
04:55 PM
