Need RG Idenification
07-07-2004, 02:59 PM
3azagthoth
Posts: 31 - iTrader: (
It says RG series, but no number. It has V8 & V7 pickups but is not the Prestiege.
3azagthoth
Find all posts by 3azagthoth
07-07-2004, 03:33 PM
vaijem777
Posts: 2,980 - iTrader: (
What's the pickup configuration? Serial number? Which tremolo does it have (if it has a tremolo)?
vaijem777
Visit vaijem777's homepage!
Find all posts by vaijem777
07-07-2004, 05:30 PM
Ibateur
Posts: 2,947 - iTrader: (
If it only has the two pickups it will be either of the following:
320, 321, 420, 421, 520, 620
Or, heaven forbid, a 120.
The numbers ending in 1 indicate a
fixed bridge
. Anything lower than 520 will have either an Edge Pro II ('03 models and newer), or a TRS thingie (older)
If it is made in Korea, it is probably a 32X. Japan, at least a 42X.
If it is a mahogany one with a quilted Sappely top, probably it is a 520QS. If it is NATO wood with a quilte Maple top, then it is likely a 620QM.
So, look at the back of the headstock, check out what year it was made (from the serial number), and where it was made (from the serial number or from a sticker/stamp on).
If none of the above helps, post a picture.
Also, I must have left some guitars off that list. Someone will correct me.
Ibateur
Find all posts by Ibateur
07-07-2004, 11:18 PM
Petie
Posts: 2,877 - iTrader: (
If you feel confident enough to take the neck off, you will find the model number stamped on the neck and also on the pocket on the body where the neck attaches.
The above rules are a good guide, but of course Ibanez likes to throw curve balls once in a while.
Petie
Visit Petie's homepage!
Find all posts by Petie
07-08-2004, 12:58 PM
ShredOrDead
Posts: 222 - iTrader: (
Ibateur
The numbers ending in 1 indicate a fixed bridge. Anything lower than 520 will have either an Edge Pro II ('03 models and newer), or a TRS thingie (older)
I have a 420, and it doesn't have V7 and V8 -- can't be that one.
Probably a 520.
ShredOrDead
Find all posts by ShredOrDead
07-12-2004, 01:06 AM
Doink
Posts: 428 - iTrader: (
If I recall, the 4XX's switched to V series pickups around 01, along with their production move to Japan.
Doink
Find all posts by Doink
07-12-2004, 12:23 PM
ShredOrDead
Doink
Well, I know the 420 series was discontinued before that. I bought mine new in 98, and I think they had one more year.
ShredOrDead
07-17-2004, 09:26 AM
IbanezroadstarII
Posts: 405 - iTrader: (
Ibateur
What school did you goto???
IbanezroadstarII
Visit IbanezroadstarII's homepage!
Find all posts by IbanezroadstarII
07-17-2004, 04:29 PM
3azagthoth
I took the neck off and it is a 550R. What's the R stand for. It has a Lo-Trem or TRS I think. And I think mapel lamenent on the front under the paint. It chips off very easily.
3azagthoth
fixed bridge
07:35 AM
