Old 08-08-2005, 07:10 AM
wildchild247  is offline
Posts: 408  -  iTrader: (0)
Reviews: 5
Problem with RG 370 DX
Hello
I bought a Ibanez 370 DX recently
Everything in tip top shape but when I was changing the gauges of strings from 9s to 10s the tremolo could not handle it and pulled back all the saddles.
Is it possible to run a set of 10s?
Ho do I adjust the saddles and inotation of the guitar accurately.
Cheers
Wildchild
Old 08-08-2005, 09:05 AM
markg5150  is offline
Posts: 2,361  -  iTrader: (2)
Re: Problem with RG 370 DX
Check out the tech section at ibanezrules.com
You'll to adjust the trem springs to keep the bridge parallel to the body and intonation is just a pain in the @ss. But all is explained on the above site
Old 08-08-2005, 09:41 AM
lyconxero  is offline
Posts: 1,469  -  iTrader: (0)
You shouldn't have to change the intonation at all if you're leaving it in standard tuning. I have 10s on my RG370DX and it took me about 30 minutes to get the trem level, but it wasn't really hard. The backplate gives you easy access to the springs so you just mess around with them (loosening them, then tightening, then tuning) until you get the trem set exactly where you want it.
Old 08-08-2005, 10:25 AM
Reviews: 5
could the springs be the fault??
they dont seem to have a strong pull on them.
the screws for tightening the trem are almost to the maxand it still doesn't work
Old 08-08-2005, 11:14 AM
damo7v  is offline
Posts: 1,150  -  iTrader: (10)
then you can try adding 1 or 2 springs.
Old 08-08-2005, 11:58 AM
Reviews: 5
I have three springs mounted on it, with them all aimed at the center like a claw shape.
It still doesnt do the job.
anybody else have tips on setting the inotation from scratch without any special tools.
I think thats my main problem after the tremolo kinda exploded on me.
lol.
I am running custom 9-46 on them now and trying to tune it but its a bitch.
I also noticed that the springs I got were gold ones, I read they are some hassle.
Does your RG 370 DX have gold or silver springs??
Thanks
Wildchild
Old 08-09-2005, 12:00 PM
My RG370DX has gold-looking springs, but I haven't had any problems with them. I did trem them a little bit though instead of adding more springs and that seemed to do the trick as far as allowing me to put 10s on the guitar.
Old 08-10-2005, 09:42 AM
Reviews: 5
What did you do to your springs??
How secure is adding extra springs into the screwholes??
Old 08-10-2005, 12:06 PM
When I was first trying to get the guitar to hold it's tuning with 10's I thought about adding another spring. But then I realized that it wasn't necessary because there's this little black piece that goes over the three springs and I would've had to take them off. Plus adding more springs will just make the trem feel tighter. So instead I just cut a little piece off of the springs and re-attached them and that did the trick. You can cut them with a strong enough wire cutter without a problem. Just make sure that you don't cut off but a little bit at a time AND that you can find extra strings in case you mess it up.
Old 08-10-2005, 01:21 PM
Reviews: 5
Can you buy stronger springs?
because my springs are over stretched and very loose.
Also I heard that the silver coloured ones are stronger.
Cheers on the tips
Old 08-11-2005, 10:30 AM
You can buy any kind of springs you want. Any guitar shop that does repair work should have some on hand.
Old 08-15-2005, 11:25 AM
Reviews: 5
The place where I live Ireland has none.
They offered me these midget ones that were for a childs toy or something.
Anyone know online I can get some.
Anyone heard of all parts.
Wildchild
Old 08-15-2005, 12:05 PM
http://www.stewmac.com/
They sell all kinds of parts.
Old 08-22-2005, 07:59 AM
jem_fanatic  is offline
Posts: 212  -  iTrader: (0)
Talking
hey man i put a set of 10's on my rg370 and all i had to do was screw in the metal bit on the back of the guitar where the springs are in further, make sure you loosen the strings before yuo do it put them like a step down or something and then tighten the back, it should work no problem, hey where in ireland you from?
Old 08-30-2005, 09:32 PM
Reviews: 5
problem fixed
I am running 4 springs now and I am not using 10s I am using custom gauge 9-46
thanks for the help guys
you really helped me.
i am from the deep south, scum hole of the south, Waterford boy, waaaaaaahhhh boy, degly dush dush techno techno, land of the nackers, I'll bust ya if ya don't give us a go of your shoes boy.
Sorry but I hate the scum in this town.
Where are you from??
guitar shop, trem springs
Problem with my ibanez rg 1570! yannvii Other Ibanez Guitars (including Premiums) 1 05-26-2008 04:51 PM
rg 1527 locking nut problem shreddies Other 7-string Guitars 3 08-04-2005 08:10 PM
ibanez rg 1570 problem bbkane Other Ibanez Guitars (including Premiums) 6 01-17-2005 11:00 PM
Eek! RG neck problem - help! Fink Floyd Tech: Setup, Repairs and Mods 2 08-01-2003 11:17 AM
RG 620X Wiring Problem kirk Tech: Setup, Repairs and Mods 43 08-23-2002 05:51 PM
