Old 11-17-2005, 04:54 PM
eatsleepplayguitar  is offline
Posts: 65  -  iTrader: (0)
questions about Changing Pickups
I want to change pickups in my ibanez guitar.
Do i just cut the wires on one, and soder the new one in?
Old 11-17-2005, 05:01 PM
Mr. S  is offline
Posts: 312  -  iTrader: (1)
Re: questions about Changing Pickups
nonono!!! dont cut the wires!! simply un-solder the pup wires from the relevent parts (pots and pickup switch) there are other sites that can guide you through this in great detail, but im sure a fellow forum member will fill you in more in depth, failing look in the pickups and wiring section, theres bound to be something you can use in there, good luck all the same.
Old 11-17-2005, 05:02 PM
bluealien  is offline
Posts: 959  -  iTrader: (0)
If you get lost, asuming you are installing Dimarzios, they have the JEM wiring diagram on their web site.
Old 11-17-2005, 05:22 PM
Does every pickup have a dif wiring diagram?
i want to change the Inf4 bridge with a evo
Old 11-17-2005, 05:34 PM
Well it depends on the configuration / switches & pots and if anyone else was in the guitar prior to you getting it. I would suggest looking at the wiring diragram that meets your confiuragtion, they are easy to read. so just follow the wire colors and you will be fine.
You can also test this with out install it fully back, I would say, remove trem, remove pickguard, flip over install new pickup, then you can plug her in, use a screw driver to touch the poles on the pick ups, to hear if it works.. if ok put all back together , then go get a snack, because you will be playing this pup all night.
pickup switch, wiring diagram
Changing string gauge questions ZenekZelman Tech: Setup, Repairs and Mods 4 10-24-2005 02:45 AM
Questions on EMG pickups. guitarkatana Pickups & wiring 20 02-27-2004 10:06 PM
Beginner at changing pickups RG-Head Pickups & wiring 20 05-05-2003 01:21 PM
Changing pickups on RG-570 marianozz Pickups & wiring 6 07-17-2002 08:11 PM
