Old 11-13-2009, 04:22 AM
Alpha_AI  is offline
Posts: 10  -  iTrader: (0)
Questions about setting up low action
Hello,
I now own a RG770 and I need to set it up near perfectly.
So i have a few questions
What do they mean by the following:
1. 1.6 mm (1/16 inch) minimum open string clearance at fret-24
(Tremolo Bridge Height Adjustment)
2. "The thought is to not have pivot point contact as it can cause wear on the posts or knive edge contact"
What is the 'Posts or Knive Edge Contact'?
which can be found at
http://www.jemsite.com/articles-menu...bridge-height/
Thanks
Old 11-13-2009, 06:48 AM
Hub  is offline
Posts: 282  -  iTrader: (1)
Images: 1
Re: Questions about setting up low action
1. Means 1.6mm clearance between top of fret 24 and underside of string, but you can set that any way you like, check the link above
2. They mean that turning the trem studs with full string pressure on them might be harmful to the studs and knife edges, but IMO that's not the case.
need help on setting action low extigy Tech: Setup, Repairs and Mods 1 12-15-2005 07:03 AM
Setting the action Labrie Tech: Setup, Repairs and Mods 3 06-07-2005 11:53 PM
Setting action on a hardtail? moro Tech: Setup, Repairs and Mods 1 04-25-2005 11:27 PM
Setting action on UV777... Bluestreak JEM and Universe Guitars 9 12-30-2002 07:28 PM
help setting the action with lo pro edge - i want low even a puppiesonacid Tech: Setup, Repairs and Mods 5 08-02-2001 04:34 PM
