Sponsor Us
About Us
Community Blog
Other Ibanez Guitars
recessed edge pro bridge..
Search
Today's Posts
Discussion about other Ibanez 6-string Guitars not covered in the above topics.
Registered Members don't see these ads.
Register now
it's free!
01-21-2004, 03:51 PM
gn86
Posts: 30 - iTrader: (
Hi,
I know all you guys will think like "what the ****? recessed??".. I love making those steve vai stuff with my whammy bar, but fact is that altough Ive had my RG570 with a
Edge bridge
at a proffessional tech two times (yes two times, yes hes proffessional) it wont get or keep the tune..when I blocked that thing, it did... So on my next guitar I thought a recessed floyd would fit me better..
Ive seen recessed edge bridges on old artist guitars.. they seem pretty sweet.. but question is: are there any recessed
edge pro bridges
Register now
it's free!
gn86
Find all posts by gn86
01-21-2004, 03:58 PM
matt_cater
Posts: 387 - iTrader: (
i always thought they were recessed. as apposed to the floyd on EVH's guitars being non-recessed ?
matt_cater
Visit matt_cater's homepage!
Find all posts by matt_cater
01-21-2004, 04:10 PM
gn86
whoops.. what a mistake.. I (of course) mean non-recessed..
gn86
01-21-2004, 04:20 PM
darren wilson
Posts: 5,629 - iTrader: (
I think what you
really
mean is "non-floating".
The recess isn't necessary to have full-floating trem operation... you can set up any
trem guitar
to float by shimming the neck up at the heel or by angling the neck cavity to get the strings up above the body.
However, some players like having their strings really close to the face of the guitar, so recessing the trem just allows the bridge to be sunken into the body of the guitar and allowing for zero
neck angle
relative to the body. If you like your strings that low, you pretty much have no choice but to recess the bridge.
So if you like the low string-to-body distance and having a trem, you'll either need a very shallow recess or just block the trem so it goes down only.
darren wilson
01-22-2004, 04:50 AM
nuno
Posts: 5,052 - iTrader: (
gn86,
you better get a fixed-bridge guitar.
nuno
Visit nuno's homepage!
Find all posts by nuno
01-22-2004, 12:58 PM
gn86
hey.. Ive thought about it.. but.. I cant get used of not using the whammy bar since I use it alot..
gn86
01-22-2004, 08:39 PM
MicJustMic
Posts: 796 - iTrader: (
Click the pink and green banner at the top of this page and check out the "Tech" section, mainly look at #13 on the list of pages there . . .
Your problem isn't that it's floating, or recessed, it's going to be something totally unrelated.
Bad studs perhaps, dull knives, posts not locked maybe?
Loose nut? Strings not stretched properly?
The Edge, even with bad studs AND flat knives WILL hold tune when everything else is properly set up. The only problem in that case is when you pull up and release the bar it may come back a bit (or a lot) sharp, but a quick tap down and it will go back to "perfect" tune.
Check out Rich's site before you assume it's JUST because it's floating/recessed as that really isn't a cause of tuning problems.
Mic
MicJustMic
Find all posts by MicJustMic
01-23-2004, 12:11 AM
bachle7
Posts: 365 - iTrader: (
tighten the studs
I would double check that the studs are tightened. Those tiny little hex screws inside the studs caused me headaches... until I knew they existed! Rich's tech setup led me to the light.
bachle7
Visit bachle7's homepage!
Find all posts by bachle7
01-23-2004, 12:26 AM
Petie
Posts: 2,534 - iTrader: (
I've recently been experimenting with a fun little technique: if I bend a string while sustaining another, I just push lightly on the bridge (or point the bar towards the rear
strap button
and push it) at the same rate as the bend. I probably wouldn't attempt it on stage until I'm fully confident with it, but you would be amazed at how well it works, and if you use the bar to do it it looks REALLY cool.
Petie
Visit Petie's homepage!
Find all posts by Petie
01-30-2004, 10:33 PM
Dr_Guitar
Posts: 52 - iTrader: (
Even Steve Vai uses a tremsetter (the Ibanez type). I put them in for a lot of customers & they say the guitar returns to pitch without fail. I prefer the full floating trem, but I think you should look into a new S model with the
Zero Resistance Trem
. It has a built in
trem setter
that really works well. The ball bearing pivots make for really smooth operation.
Dr_Guitar
Find all posts by Dr_Guitar
01-31-2004, 07:07 AM
gn86
Dr_Guitar
Even
Steve Vai
uses a tremsetter (the Ibanez type). I put them in for a lot of customers & they say the guitar returns to pitch without fail. I prefer the full floating trem, but I think you should look into a new S model with the Zero Resistance Trem. It has a built in trem setter that really works well. The ball bearing pivots make for really smooth operation.
sounds nice.. is it easy to tune? I mean.. do I have to go through all that ****ing bull**** just to change the tuning as I would on the usual thing?
gn86
Bookmarks
Digg
del.icio.us
StumbleUpon
Google
edge bridge
edge pro bridge
edge pro bridges
neck angle
steve vai
strap button
trem guitar
trem setter
zero resistance trem
jackson kelly floyd-rose licensed bridge
floyd rose original bridge screw posts
make a bass plate for strat bridge pickup?
Alex lifeson sound neck or bridge pickup
04:10 PM
