RG-470 sounds weak...
02-08-2007, 04:12 PM
skrewflanders
Posts: 215 - iTrader: (
I recently put in a BL XL-500X in my 470, it sounded great at first, but now it seems to sound really weak and thin like a strat, in a real bad way. i have no idea what could be doing this, i'm using a 500k pot, any ideas?
skrewflanders
Find all posts by skrewflanders
02-08-2007, 04:19 PM
Shredder87
Posts: 417 - iTrader: (
Re: RG-470 sounds weak...
Check your solder connections... you might have a dry or loose joint.
Shredder87
Visit Shredder87's homepage!
Find all posts by Shredder87
02-08-2007, 04:24 PM
skrewflanders
i'm not even sure if i wired it correctly now that i really look at it, does anyone have a diagram by chance? i'm using a five way switch.
skrewflanders
02-09-2007, 01:24 AM
xeroparadox
Posts: 31 - iTrader: (
what pickups do you have in total
neck, bridge and middle(if applicable)
im assuming the neck and bridge are hums, is the middle a single, a humbucker/hum-cancelling single, a standard single, or is it not there?
xeroparadox
Find all posts by xeroparadox
02-09-2007, 05:26 AM
the.godfather
Posts: 3,593 - iTrader: (
It sounds like a weak solder joint to me too.
Just double-check the connection, and maybe re-solder it completely to see if that is the problem.
the.godfather
Find all posts by the.godfather
02-09-2007, 05:57 AM
madpickin03
Posts: 531 - iTrader: (
You can find plenty of wiring diagrams on
seymour duncan
's site. Make sure you just use it as a rough guide and not follow it completely since the color code's different.
Resolder the whole thing again.
madpickin03
Visit madpickin03's homepage!
Find all posts by madpickin03
02-09-2007, 01:26 PM
skrewflanders
ya i have the BL 500 neck, and just the standard single in the middle (the one that came with the guitar). i'm just going to redo the whole thing. thanx guys
skrewflanders
02-11-2007, 09:07 PM
neptoess
Posts: 303 - iTrader: (
it sounds like you bought the Bill Lawrence USA L-500. If it was not purchased from
www.billlawrence.com
its prolly mass produced which means it may not have been thoroughly tested before distribution which means it could be a **** pup. I love my L-500R/L-500XL to death.
neptoess
Find all posts by neptoess
02-12-2007, 02:55 PM
skrewflanders
ya i got a cheap crappy one at first, asked here, and then got a good one direct from them. rewired the whole thing, sounds much better.
skrewflanders
02-13-2007, 03:23 PM
xeroparadox
get wiring diagrams from either dimarzio or duncan. theyll have what you want unless you want some funky setup
xeroparadox
seymour duncan
wiring diagram
which one sounds better a les paul or a sg?
humbucker sounds like yngwie's neck pickup?
marshall sounds from a tri-axis?
how do you get your amp to the brown sounds
What amp sounds good with the Jemini pedal?
RG GOLD and RG METAL
cowcowcow
09:17 PM
FS : ibanez RG USA CUSTOM 1991 UCEW1FM
fredperry
04:34 PM
What kind of RG is this?
ethere
07:55 PM
DIfference of sound between rg 2550 - rg 2820
Pezi
04:21 AM
rg 470, rg 320 fm or rg 350 dx?
antonioua8
11:45 AM
03:24 AM
