Old 02-27-2013, 11:41 AM
IronMaidenRocks  is offline
Posts: 7  -  iTrader: (0)
RG 550 / Lo-TRS - which spare parts fit?
Hello everybody,
I own an RG 550 with an Lo-TRS trem on it. On todays string changing process one of the little blocks, that press the string into the trem (via screw) fall to the floor and i'm not able to find it. As the other 5 blocks that are in there seem to bee quite worn off i'd like to exchange them all. Which parts can I use? Sadly the ibanez website wasn't helpful to me. I thought that these blocks from alternative systems like Gotoh or Schaller could fit - any tipps (instead of changing the whole system)?
Thank You in advance!
Old 02-27-2013, 12:12 PM
maqify  is offline
Posts: 1,274  -  iTrader: (1)
Re: RG 550 / Lo-TRS - which spare parts fit?
You might be able to find what you need at http://www.ibanezrules.com/parts.htm.
Check it out. I have no Lo-trs so i don't know if the blocks that fit a OE or Lo-pro edge would fit. If you got a guitar with that trem check them out.
Old 02-27-2013, 04:42 PM
silverctr  is offline
Posts: 880  -  iTrader: (4)
Images: 2
Reviews: 15
Depending on what it's made of, you could probably run a magnet over the floor and see if it gets picked up.
Old 02-28-2013, 01:37 AM
B.B.A.  is offline
Posts: 257  -  iTrader: (3)
This is off topic but as far as I know, the RG550 came with edge or lo pro edge, not Lo-trs. Have the tremolo on your guitar been swapped? or maybe it's not an RG550?
Old 02-28-2013, 04:21 PM
LonePhantom  is offline
Posts: 7,337  -  iTrader: (8)
Reviews: 120
That's what I was thinking. Can you post some pictures of the guitar and close up of the bridge so we can see what you have? If the bridge has "LO-TRS" stamped on it it's not a 550.
Old 02-28-2013, 08:00 PM
maqify  is offline
I thought this as well, only OE and Lo-pro edge on the 550. Today i came across a 550(according to the seller) but it had Lo-TRS stamped on the trem. My conclusion is that(without pictures-so i could be wrong) a "RG550" looking guitar with Lo-TRS trem would be an Ibanez RG450 mij. But pictures of the acctual guitar would be a big help.
Think that the pickguard on the 450 makes people think it's a 550.
Old 03-02-2013, 02:14 PM
D.M.RG7620  is offline
Posts: 2,765  -  iTrader: (1)
Reviews: 11
Sounds like an RG450 to me.
And those little blocks are everywhere. I'm not sure if its 1 size fits all or not but any guitar center will carry the All Parts blocks. They come in 6 packs. Worked fine in the Original Edge and Lo-Pro I put them in. I doubt that they'll be any different in a TRS.
Do you have a Guitar Center near you that you can check?
lo-trs, spare part
Need spare parts for RG 550 - Where to buy Josh_P Other Ibanez Guitars (including Premiums) 1 10-11-2009 01:26 AM
FS: Several Ibanez Spare Parts (UK) Max Dread Classified Ads: Guitars and Gear 0 04-24-2009 04:41 PM
FS Tons o' Spare Parts! Dunadan Classified Ads: Guitars and Gear 0 07-11-2007 02:04 PM
Spare parts on **** ?! lalope Vendors, Auction & Reseller Talk 0 12-24-2005 06:25 AM
Spare Parts in the uk Al M JEM and Universe Guitars 6 09-08-2002 07:03 AM
